Mixing RMG and PO106FF
apotelyt
i've read in the forums that this combination of Clearkote RMG and Menzerna PO106FF with a mixing ratio of 60%:40% or 70%:30% (PO106FF : RMG) gave great results when finishing up. Will this work if i were to use a sealant as a LSP like Zaino or FMJ..? Since RMG is a glaze and will this affect the bonding properties of the the sealant?
thanks..
that sounds like a delicious mix, but I too wonder how well sealants specifically would attach and cure to it. I would likely top with a carnuaba after all that work.
It sure does sound interesting. Post pics if you can, I am curious what the results will be.
I need to pick up some RMG to try this out..Bit reluctant to do this as i intend to use a polymer or acrylic sealant as my LSP. I read the mix gave a good working time. I 'll try and post the link of this discussion once i find it...
according to "Rag", a 70%":30% mix shld not affect the bonding properties since the amnt of RMG is too low to exhibit much of its glazing properties..The idea of the mix is to reduce dusting and increase working time. They also tried it with IP and hd similar great results.
