MJJC Foam Cannon which one?
PeteT19640
Member
Hi please can you tell me the best out of their range.
Would imagine the Pro2. 0?
I see there is one for Karcher K series.
Thanks in advance
The best reviews I've read and heard have been about the MJJC Pro 2.0. There are bunch of reviews out on YouTube which might help you
Yeah the 2.0 seems to be the one. Question why not a MTM PF22.2 if spending that much?
Thanks I will have a look.
Foam Cannons are totally new to me.
Ok will take a look at those too.
What maybe the advantages will the MTM have over the MJJC?
I’m not familiar with MJJC but MTM has been the quality standard for many years now. Standard suggestion for this forum anyway.
The MTM PF22.2 is the industry leader, very well made and can be repaired with spare parts.
Considering the price difference between the MJJC Pro and MTM is less than $10.00, just get the MTM. Both can be adapted to any pressure washer.
MTM Hydro PF22 Professional Foam Cannon
How much wash concentrate do you use for one of these. I have heard anything from 60ml-200ml, big difference?
Depends on the soap, but I'm normally at 100 - 150ml.
Thanks for that
Thought it was a bit strange that the new one tended to fall over
They are better now but still a little unstable. I would use a Kwazar 500ml bottle on it. It can go on a 1L bottle as well if you can get a longer tube in it.
I use from a domestic brand here in Sweden. But Trinova had these bottles before. They are 800ml and the tube fits perfect. And it gets very secure with these bottles.
Skickat från min SM-T736B via Tapatalk
I used to use 4 ounces (120 mL) of soap with 1 ounce of foam booster in my first cheap foam cannon and I still could not get good foam. Now I use the MTM PF22.2 and I only need 2 ounces of soap with 1/2 oz of foam booster and I get great, thick, clingy foam. I like the new bottle design. I still have the top heavy version.
