Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Modified 10 @ 10 Technique for the Rotary Buffer
At the last Detailing Boot Camp Class I had the opportunity to do a lot of work with Tyler who at age 15 is keenly interested in the craft of detailing cars and the art of polishing paint.
Seriously, this kid is after my job...
IF you look closely, instead of picking up his bead of product at the 10 O'clock mark on his buffing pad Tyler is going to reverse directions and thus pick his bead of product up at the 4 O'Clock position. For this version of the 10 @ 10 Technique you move the polisher left to right and this way you pull the product into the pad instead of splattering it all over the place.
After passing over the bead of product he then quickly lays the pad flat to the paint and starts removing his sanding marks.
Here's Tyler, learning to hold the pad flat while holding the head of the Flex PE14 Rotary Polisher
Freestyling....
And here's Tyler moving to the other side to continue removing sanding marks. He makes it look so easy and that's the sign of a future Pro!
Nice work Tyler...
:xyxthumbs:
Freestyling....
Nice work Tyler...
:xyxthumbs:
