Elliot@Autogeek
- Apr 24, 2017
- 362
BLACKFIRE Water Spot Remover
Make sure no spots interrupt your car’s shine!
BLACKFIRE Water Spot Remover works to effortlessly break down the mineral deposits on your paint that cause water spots. BLACKFIRE Water Spot Remover is made using a safe formula that does not contain any acids or abrasives that could harm your paint, no matter what type of paint it is! Not only will BLACKFIRE Water Spot Remover get rid of the spots, it will also prevent them from occurring in the future thanks to the hydrophobic layer of protection it leaves behind.
Having to deal with water spots on a daily basis is a big enough pain to make any detailer or enthusiast rip out their sprinkler system and wrap their car in saran-wrap. But, unfortunately, as long as rain is an important part of the continuation of our planet, we are forced to deal with these pesky little spots day-in, day-out. However, while they are unavoidable, cleaning them off and protecting your car as best as you can just got a bit easier!
We call these pests “water-spots”, but they are actually not water. They are simply the clumps of minerals that were contained within your water that were left behind after the water had all evaporated. These minerals form a strong bound both to each other and your paint, making removing them very difficult. BLACKFIRE Water Spot Remover makes this removal process much easier by using a non-abrasive, acid-free formula that breaks down these minerals. Once they are broken down, the bonds are broken as well. This makes them extremely easy to harmlessly and easily to wipe them away!
There are many products on the market that promise to do the same job as BLACKFIRE Water Spot Remover. Many of them are just as effective, but almost all of them share one aspect with each other that they don’t share with BLACKFIRE Water Spot Remover. Those other mineral removers are formulated using either strong acids, dangerous abrasives, or worse extremely strong acids. These substances are extraordinarily dangerous and will cause permanent damage to your paint if you are not extremely careful. BLACKFIRE Water Spot Remover however, does not contain any of these dangerous substances, meaning you can rest assured that your paint is always being taken care of!
__________________
Removing fresh water spots using BLACKFIRE Water Spot Remover is as easy as spray, wipe, and walk away! Don't forget - in addition to your paint having no more water spots, there is also a layer of protection left behind!Make sure no spots interrupt your car’s shine!
As if cleaning of the water spots fast weren’t enough for BLACKFIRE Water Spot Remover to be on your list of must haves, the fact that it will also protect you from the risks of water spots by instilling a hydrophobic layer of protection after you have used it!
Directions:
Water Spot Remover is recommended for the removal of fresh water-spots. Water Spot Remover should only be applied out of direct sunlight to dry paint that is cool to the touch.
Working one panel at a time, spray Water Spot Remover directly onto the surface of your car. Using a clean and dry microfiber towel, wipe Water Spot Remover off the surface. Continue around vehicle.
BLACKFIRE Water Spot Remover - Now in Stock! Free Bonus!
Our Price: $19.99
For a limited time only, receive 16 x 16 Blue/Grey MicroEdge Microfiber Towel Dual Plush Towel FREE with your purchase!
BLACKFIRE Water Spot Remover 128 oz. - Now in Stock!
Our Price: $59.99
BLACKFIRE Remove & Prevent Water Spots Combo
Our Price: $100.92
Sale price: $69.99
BLACKFIRE Glass Water Spot Remover
BLACKFIRE Glass Water Spot Remover easily removes mild to moderate water spots that plague your glass surfaces and ruin the all-around look of your car. BLACKFIRE Glass Water Spot Remover also improves your safety while driving by increasing the clarity of your glass and improving your visibility. You don’t need to by any special tools to use BLACKFIRE Glass Water Spot Remover as it can be applied by hand or machine!
Water spots have long been a terrible annoyance to anyone who puts even the slightest bit of worth in how their car looks. When the goal is to make your car’s surfaces look shiny, it is quite irritating when those surfaces are instead peppered with hundreds of small round mineral deposits, also known as water spots. Not only to they ruin the look of the surface, that are also nearly unavoidable and quite a chore to remove once they are there.
Your glass is especially sensitive to these devious little deposits. They are much more noticeable on a transparent surface AND that transparency is compromised when it is littered water spots, which can cause a safety hazard. For the sake of your car and your safety, BLACKFIRE came out with an easy solution to this treacherous issue. BLACKFIRE Glass Water Spot Remover will make solving your water spots issue easier than you would have guessed.
BLACKFIRE Glass Water Spot Remover uses mild abrasives to gently remove the water spots that have built up on the surface of your car. The abrasives in BLACKFIRE Glass Water Spot Remover are strong enough to tackle mild to moderate water spots, but not so aggressive that they will permanently scratch the surface of your glass.
BLACKFIRE Glass Water Spot Remover will also greatly increase your safety while you are driving as well! You will notice a distinct improvement to the visibility and clarity of your glass after it has been treated with BLACKFIRE Glass Water Spot Remover. This increased visibility allows you to see more clearly while you are driving instead of constantly having your vision impaired by the water spots that populate your windows and windshield. Especially while driving facing the sun.
Not everybody is equipped with the tools and appliances of a professional detailer, so you may not have access to a polisher or buffer that would allow you to use a standard glass polish effectively. BLACKFIRE Glass Water Spot Remover, however, was designed for easy use either by hand or by machine. This makes BLACKFIRE Glass Water Spot Remover an ideal choice for either the professional detailer or the detailing enthusiast!
Directions:
Hand Application - Apply a quarter-sized drop of product onto a foam or microfiber applicator pad. Working on a 10" x 10" area of glass, apply Glass Water Spot Remover using an overlapping, back and forth pattern. After completing a section, immediately wipe off any excess product with a clean and dry microfiber towel. Repeat through each section.
Machine Application - Before starting, tape off any painted areas to avoid splatter. Apply a quarter-sized drop of product onto a light foam polishing pad and apply to a section of glass on medium to high speed. Be sure to use overlapping passes to ensure each inch of glass is treated. Once product turns clear, remove any excess product with a clean microfiber towel and evaluate. Repeat if necessary. Follow through each section of glass using the same technique.
BLACKFIRE Glass Water Spot Remover Now in Stock! Free Bonus!
Our Price: $24.99
For a limited time only, receive 3 qty. 16 x 16 inch Edgeless Microfiber Towels FREE with your purchase!
BLACKFIRE Glass Water Spot Remover 128 oz. Now in Stock!
Our Price: $69.99
BLACKFIRE Paint and Glass Water Spot Remover Combo
Our Price: $77.92
Sale price: $49.99
BLACKFIRE Spot-Free Glass Kit
Our Price: $67.95
Sale price: $49.99
