All right, seen the videos. Got timing down. I am a liitle fuzzy after the initial polish application on the pad. How much after you start. I put a "x" on pad' do a section.
Does one put a few drops, an x? afterwards?
Kelly: I typically do another X on the pad in an unused area (so eventually, there is a starburst pattern on the pad). This will enable the use of small amounts of product on the original X.
