I am about to paint the roof of my car. I will need to wetsand afterward for any mistakes I make and level the clearcaot. I want to know what is the best polish/pad combo for a Porter Cable 7424 to remove 1500-2000 grit sanding scratches.
I mainly use Menzerna Intensive Polish and Final Polish 2 so I am not as familiar with newer/other polishes/compounds. Last time I painted I found that Menzerna IP and a 4 in orange LC foam pad did not quite get all the sanding marks out and it was a lot of work, had to go with some 3M compound mixed with IP to make it workable and it improved but was still not perfect. I recently tried Mequairs Ultimate Compound with a micro fiber pad yet it was no more effective on 2000 grit sanding scratches and deeper scratches then a common polish like Menzerna IP.
What is the best/most aggressive combo for a PC to use to compound/polish out 1500-2000 sanding marks and deeper scratches? I was thinking Griots Fast Correcting Microfiber pads(any recommendation on size) and Griots Fast Correcting Cream, I read good things about that combo. Any other recommendations?
