most durable, best looking combo
budhoehn
These are the combos I am going to try, let me know what you think.
Blackfire TPnS with Crystal seal or BFWD topped with Polymer Sealant
Duragloss 601/105/501 (some combo of these) topped with Aquawax
D151 topped with OCW
Right now I will be doing this by hand so I don't expect any real correction but when I get a DA that will change.
I am no pro....but I would use TPnS, BFWD then use Crystal Seal, then you can use the Poly Spray to tune up after every other wash or so. That is what I used on my car.
You might actually notice some improvment with d151 depending on how much you work at it.
DG 501/601 topped with Aquawax FTW!!!! Durable, cheap, and looks great!
I've tried a bunch of different combo's of wax'es and sealants. 95% of the time anymore I stick with 1 I like and just layer that twice. I haven't noticed a big enough difference in layering products to really warrant the extra work and money. The only two products that I do like to layer is BFWD + Midnight Sun and Menzerna Power Lock + Collinite 845. There has been a lot of talk about if the 845 will remove the previous layer of (insert sealant name here) but I have had great luck with it. I haven't used ANY Duragloss products unfortunately :(
I almost forgot I do have some 845 also. Just trying to find the best and fastest way to get good looks and durability and then use a spray after washes to bring it back some.
