Most durable finishing wax?
mcpp66
Where I live the water is quite hard so I really never get through a car wash without water spots. I'm looking for a way to be a bit lazy. After I finish drying the car I'd like to start using a finishing wax with a DA so that I can put protection on the car and remove water spots at the same time. My first thought was Meguiar's finishing wax that's part of their DA correction system. I called Meguiar's and asked about that and he said that while it does offer protection it's not the most durable out there. Any recommendations for a finishing wax that offers strong protection and can remove water spots at the same time? Thanks.
That sounds like a job for Duragloss 101, which is a cleaner sealant. Very effective at cleaning, very durable, and gives a fantastic gloss.
If you switched to Optimum No Rinse type of rinseless wash, that might mitigate the waterspotting.
Are Finishing-Waxes really suppose
to have any cleaning ability?
IMO:
Sounds like a Cleaner-Wax/Sealant
might be more appropriate for the
situation you outlined in your OP.
I would do a wipe down with a QD product after the wash. It's takes those water spots that are new right off. To get a little more economical you have the waterless wash or rinseless wash that also can be diluted to QD solution.
/Tony
Just to chime in...
Note the text I made red
I'm looking for a way to be a bit lazy. After I finish drying the car I'd like to start using a finishing wax with a DA so that I can put protection on the car and [B]remove[/B] water spots at the same time.
Are Finishing-Waxes really suppose to have any cleaning ability?
IMO:
Sounds like a Cleaner-Wax/Sealant might be more appropriate for the situation you outlined in your OP.
Bob's correct. A true finishing wax or a show car wax has zero cleaning ability. It's purpose is to provide beauty and protection. It should only be used on a surface that is in new or perfect condition. The same thing goes for a finishing sealant or a show car sealant.
Sounds like what you want is a one-step cleaner/wax or AIO (AIO and cleaner/wax or cleaner/sealant are all the exact same thing, just different words to describe them)
The problem with getting long durability with anything that cleans or abrades is that while the product is cleaning it's protection, while it's protecting it's also cleaning.
I'd recommend a combo I use for daily drivers and that's buff out with BLACKFIRE One Step using a foam polishing pad and orbital polisher and then apply SONAX Polymer Net Shield. As long as you're washing CAREFULLY - this means you're not scrubbing the surface, most people say they get 6 months out of PNS or Polymer Net Shield. It is a very unique product.
I describe PNS as a product that is as close as you can get to a ceramic coating but it's not a ceramic coating.
Here's the good news, you can now get it in a 250ml spray can. The reason this is good news is because a little goes a long way and a full size can will pretty much last you for years, so if you're only doing your own car, just get the little can.
SONAX Polymer Net Shield 75 ml. - $9.99
SONAX Polymer Net Shield 340 ml. $29.99
Get them both here,
BLACKFIRE One Step $39.99
SONAX Polymer Net Shield 75 ml. $9.99
I would look at Poorboys Polish with Sealant. I wouldn’t use it every time I wash. It should remove light water spots.
Might also want to consider a ceramic coating to minimize the possibility of water spots in the first place.
