Now that I take a better look at it, it appears to be a Honda Element, right? What year is it?
I don't recall the rear bumper being white on all of them, so any info you can provide would be appreciated. Here's an image I found on-line:
ViperGuy - the oiliness you describe is a common side effect from applying too much product. Any chance you applied too much aerosol?
Can I still use Mothers Back-to-Black Trim and Plastic Restorer on the grey plastic panels on my Honda elements?
Yes, it's perfect for those areas. You should consider buying our Back-to-Black Heavy Duty Trim Cleaner kit as well - having a clean surface will allow the dressing to lay evenly, and last longer since it's on the trim itself and not just laying on dirt or oxidation.
