Ron Atchison
- May 2, 2011
- 1,034
First I would like to thank Forrest and Jim because without their generosity these reviews wouldn’t be possible and you guys would be missing out or overlooking some very good products.
As you may know I was given the opportunity to review quite a few of the Mothers products. For this review I chose to do Mothers Chrome Wheel Cleaner.
As with most Mothers they are very easy to find at almost any retailer or auto parts store which means no shipping charges or waiting on products which is a real plus.
The car chosen for the review is my mother’s 1998 Cadillac Eldorado because it has nice big chrome wheels and hadn’t been washed since the last time I did it last fall. Due to health issues it wasn’t driven all that much either but it did see some winter salt and grime.
Product information fromthe Mothers website. http://www.mothers.com/index.html
Mothers® Chrome Wheel Cleaner is specially formulated to quickly and easily clean chrome wire wheels, chrome plated wheels, chrome wire hubcaps and rough cast aluminum “Mag” wheels. Its unique spray on, hose off design safely penetrates, dissolves and suspends all types of brake dust, grease, dirt, and grime, making rinsing a snap, and turns the most neglected rough cast aluminum to like-new condition.
#05824, 24 oz.
Directions
1 Know what type of metal you are cleaning.
2 Work with a cool, dry surface.
3 Spray Chrome Wheel cleaner liberally on surface to be cleaned.
4 Allow foaming action to work for one to two minutes.
5 Hose off thoroughly with a strong spray of water.
6 Dry wheels with a soft, clean microfiber or terry cloth towel.
As you can see the wheels aren’t terribly dirty but there’s a nice coating of winter salt and dirt.
Mothers brushes and cleaners assembled to bring some life back into those wheels and tires. As it ends up the brushes will end up only being used on the wells and tires.
Mothers Chrome Wheel cleaner being applied, not much foaming action. The dirt and brake dust instantly started running off as can be seen on the concrete without any agitation. No strong chemical orders noticed, actually has a somewhat of a pleasant scent more of a citrus.
The wheel was then hosed off with a strong steam of water after waiting two minutes as per the directions and looked clean. From past experiences most spray on hose off wheel cleaners leave something to be desired, and I wondered just how much dirt was really still there and would the wheel still be dirty grey if it were left to dry on its own. Well there’s only one way to find out. Using an old stained soft terry towel I dried the wheel to see how dirty the towel would get, knowing there’s got to still be dirt on the wheel. Wrong! To my surprise the wheel was clean and needed no further cleaning. The upper right corner of the towel was used and the only place I still found any dirt or brake dust was in the lip of the wheel which can be seen by the two black lines on the towel.
Pretty incredible considering the wheel had months old dirt and salt on it and it was removed with just one spray on hose off application.
Conclusion
Very simple product to use with excellent results following the directions listed on the bottle.
Pros
Economical Product
Easily found
Couldn’t be simpler and works as advertised.
Cons
None
Hope you enjoyed the review J
#05824, 24 oz.
Directions
Conclusion
Pros
Economical Product
Easily found
Cons
None
