Why would you hose it off?...It's a panel wipe used before applying a LSP
Yeah I’m not sure what your plan is but the Mothers is super easy to use as is most panel preps. I would think the mechanical process of spreading and removing with a towel helps aid in removal plus these are almost all alcohol based and you’d want to make sure you get it off all surfaces.
Why not just follow Mothers directions?
Right. The mechanical function of wiping off the panel prep with a MF towel is crucial to creating a clean surface ready for the protection layer.
