Mothers Trim Cleaner and Wolfgang Exterior Trim Sealant Help
3MW
I just ordered these items to use on black unpainted plastic bumpers, mirrors, door handles, and rubber seals (2 months old). I believe I have a pretty good idea of what to do, but I still have a few questions and can use any help or tips you don't mind sharing. My plan is:
  1. Wash
  2. Dry
  3. Apply B2B cleaner and scrub with brush.
  4. Wipe off B2B with microfiber towels
  5. Apply WETS with foam applicator pad
Now some questions:
  1. What are some good brushes (manual and for da polisher) to use with B2B on large areas like the bumpers?
  2. Should their be anymore prep between steps 4 and 5?
  3. How to remove B2B splatter from paint due to application with brush?
  4. How to remove WETS if it accidentally gets on the paint?
  5. Can I use these products in direct sunlight?
These Mothers Brushes are good for scrubbing larger areas with the Mother B2B Trim Cleaner. But really any nylon brush can be used, just make sure it’s not too aggressive for your 2 month old vehicle.
Mothers Detail Brush Set cleans crevices and creases inside your car. Mother Detail Brush Set includes 2 small brushes.
No additional prep between 4-5 is needed.
Remove any splatter with waterless wash i.e. McKee’s N-914.
Should be used on a cool surface.
Note: If your rubber weatherstripping is only 2 months old, you may only need to use the cleaner with a microfiber towel. No need to be overly aggressive if it’s that new.
