Mothers Wax Attack 2 Polisher
Ron Atchison
I was at SEMA a few weeks ago and while visiting the Mothers display I got the opportunity to use the new Wax Attack 2 polisher on a test panel with 3000 grit sanding scratches in it to replicate typical marring on a daily driver. Looking at the polisher and pads I really wasn’t expecting it to perform all that well compared to the professional quality polishers and pads I’m normally used to using but it actually did quite well. More on that later.
Mothers designed the polisher using industry trusted dual-action random-orbital technology and have assembled it in a kit form. The complete kit includes the Wax Attack 2 Buffer, Pads (x3), 12 oz. Professional Rubbing Compound, 12 oz. Professional Finishing Polish, 12 oz. California Gold Synthetic Wax, 16x16 Microfiber Towels (x3) and comes in a hard plastic carrying case.
The kit was designed to be safe and simplify the steps from compounding to waxing so all of the pads are the same. That’s the part that surprised me at just how well it actually worked. The soft pad teamed up with the compound from their professional line made pretty quick work of removing the sanding scratches. The compound haze was easily cleaned up with the finishing polish which happens to be one of my favorites anyway so I knew that was going to be easy to do.
The case is molded to hold all of the contents secure and organized.
The face of all the pads are flat with a centering hole. The back of the pad is recessed with the outer edge covering the outer edge of the backing plate that protects it from contacting the finish.
The hook material on the backing plate covers the whole plate and holds the pad very securely but not so strong the pad is hard to remove.
Rubber non slip panels on the polisher body and handle. Simple on/off switch easily accessed with your thumb.
The ergonomics of the polisher are very comfortable and the polisher feels very balanced even when holding it horizontal like you would on a fender or door panel.
Final thoughts:
Using the system as designed is almost fool proof even for the average guy that has never done any real paint correction before.
I initially thought I would purchase this for Christmas my brother who likes to keep his truck looking nice but has no interest in filling up a cabinet with detailing supplies and another for my sister and brother in-law to throw in their coach that makes a trip to Hilton Head a few times a year and sits for a month at a time. This kit would be perfect for them being self contained and have everything needed to maintain the paint from normal wear and tear from the trip. But now I think I’ll keep this one for myself and buy two more for them. Reason being, it never fails whenever I go to a family/friend function somebody always has something on their car they want me to look at, and the question always is “can you fix this”? Most times it’s normally something minor and having the Wax Attack kit in the trunk with me I’ll have everything I need to fix the majority of the paint issues they may have.
Thanks for the write-up. It's a heck of a machine/kit at a killer price.
Nice lanyard you have from this year's DetailFest.
Thanks for the review! :xyxthumbs:
What's the "throw" on this polisher?
TIA.
Seems like I remember that the
Wax Attack-V1 cost ~$80.
It was, but the new machine comes with 3 pads (~$10 each), 3 bottles (again, ~$10 each) and 3 towels.
So, the machine nets to less than $60 and has considerably more ability at defect removal than the original version.
I'd say it does more, for less.
It was,
but the new machine has considerably
original version.
IMO:
It can't be a whole lot...what with
the polisher having just 71.5W
I have no idea, and the person I need to ask is off today.
I've been more interested in how it worked than the technical specs, but I'll find out and let you know.
Keep in mind the kit is designed to work as a system, and it's the results of everything working together that counts.
Keep in mind the kit is designed to work as a system, and it's the results if everything working together that counts.
Ok.
Thanks Forrest.
I'm curious as well since I pulled the padlock off my wallet and bought one of these kits a few days ago. A Christmas gift to myself. I need it to remove swirl marks and if that requires several applications of the entire three step process that's ok. However if it cannot do this type correction then I will be somewhat disappointed. Time will tell.
The recessed pad designed to cover the backing plate as a protection against damaging the painted surface is a good idea, but does that suggest I will only be able to use the Mothers pads or are other pads available with similar recessed design....or does that really matter I wonder?
Mike was kind enough to shoot a how-to video with the machine a few weeks ago. Yancy mentioned yesterday he'd get it on the Wax Attack page in a day or 2.
As for pads, there are replacement pads available - the part number is 90033. I haven't sent all the info to AutoGeek yet to get them added, but they will have them.
Please keep in mind it's a system that's made to work together. Using other pads or products will likely leave you disappointed.
I sent a machine to Mike in October, and he tried it with his favorite pads and polishes. It didn't work well and Mike was concerned the machine was not up to AutoGeek standards. I asked him to try again with our pads and products, and it worked fine.
If Mike was happy with its performance, I hope you would be, too.
I'll keep an open mind, and hope for the best. I don't wish to become a car detailer just to care for my own car BETTER than I can do with a can of wax and a stack of microfiber towel. Got to handle swirl marks or it's of questionable value to me though...time will tell.
Thanks for the pad part number Forrest...:xyxthumbs:
Hello folks - where can i find the specs for this machine?
I like it because it is cheap, perfect for a beginner like me. I guess my real question is, can i plug this in a 220 volt outlet?
Your best bet will be to contact us during west coast business hours. 714-891-3364 and ask for Jimmy D, or email him jimd(at)mothers.com
It is a 110v machine though, since it is sold here in the US. If you'll let Jimmy D know what country you're in, he may be able to steer you towards a source with 220v availability.
Thank you!
