Lou M
- Jun 1, 2011
- 9
:help:
Hi, had a friend drop his windscreen and put an 11" scratch across the middle of it. I restore headlights, so I figured I'd give it a shot. It seems to have 2 layers like a new headlight that is difficult to remove, and you can see the transition between the two. A headlight is small enough that you can remove all of the top layer and refinish it. This windscreen is Huge and taking the whole top layer off and starting over would take forever. I'm wondering if a clear coat might hide the transition, has anyone tried this or have a remedy? Thanks
