Azure
Member
- May 23, 2013
- 430
- 17
Hi detailers, I've got a new PF22.2 foam canon (the one with the wider bottle) and it is putting out watery foam. I have a cheapo Amazon canon that I use for just wheel/tire cleaner that works fine, so I know it's not a weak flow issue. I have a Comet 1700 pressure washer, BTW. I played around with increasing the amount of soap and even changed to a less-thick soap, but no change. I was beginning to think it was my hard water, but I put my usual car shampoo in my cheapo canon and that worked fine. I figured it must be the filter thingy, so I disassembled and reassembled the unit. No change. I ordered a new filter from MTM and tried that this weekend and no change. I know this is a good foam canon, but I'm not having much luck with it. Is there anyone else that has had trouble getting their PF22.2 to put out foam properly? Thanks
