My solution to $150 foam guns...
muahman
$14 @ Home Depot
Works great!
link removed : G-Foam at Home Depot
Give it a shot I say.
Still spent over $600 on AutoGeek car detailing stuff this weekend. Ahhhhhhhh I can't stop!
any pics of how it foams in action? very curious about it:)
for 4000psi pressure washers??????? or is it an up to 4000psi. Pretty big difference just cause people probably won't be dropping $1350.00 on a pressure washer to get a $15 foam gun.
[ame=http://www.youtube.com/watch?v=PyvOxU6daLU]YouTube - ‪Green Technologies G-Foam Blaster‬‏[/video]
It's up to 4000psi. I blew up my gas one last night. I'm done with gas ones. I bought a electric 1700psi one. Will be fine for detailing.
Just think of all the extra shampoo and Cobra micro fiber you can buy with the extra $140 bucks you save on the foam gun! :)
I have that foam gun and I bought a foam lance off eBay. The little one at home depot works but it just runs out of foam pretty quick.
$14 @ Home Depot
Works great!
AGPWF04 at The Home Depot
thanks for the info .I have a foam canon and its sh-t payed 125.00 for it this looks good and for 20.00 cant be wrong to try it. my thing is I have a honda pw and it is a big one with a cat pump 5.5 gl per min of water I can turn it down also
I have this foam gun from hd an find it works pretty well. You don't need to turn the valve all the way open to get a good soaking of foam. When I do have it open it went through it's 8 ounce capacity quickly.
I just bought one tonight... I'll be trying it out tomorrow.
I have a foam attachment for my Karcher pressure washer and it works really good. I think it only cost like $25.00...
It has a quick connector. HD sells an adapter kit for those with an electric pressure washer.
I've got one of these as well. It does work quite well, but as stated will go through soap quickly if opened fully.
Are the threads generic and would adapt to say an old product bottle??
It has a clear canister for soap solution. I think the diameter is about 2-3", so no, I don't think you can attach an old product bottle to it. And in my case, the gun attaches to the end of my spray wand, which is maybe a foot and a half or two feet long. I wouldn't want to hang too much more weight on the end if you are thinking about using a larger capacity canister. And in reality, I can cover my whole truck with one load of soap, so its size really isn't an issue.
I am detailing a metallic white Ford Edge today... I used the foam blaster gun with my pressure washer, let the solution dwell for a few minutes, rinsed and repeated, the second time I used a microfiber mitt to gentle clean the surface.. it came out awesome!
you didnt get any swirls or scratches? I use my foam gun as a pretreatment only..
anyone have any updates on theirs? Price seems a no brainer
