Nanoskin Autoscrub system
xxnonamexx
What polisher do you recommend for the Nanoskin autoscrub system? See attached for the ones I currently own but I dislike the weight of them my arms tire out. These are 7". I am not looking to spend a fortune but I would love a good machine for nanoskin autoscrub to eliminate clay barring, the 3" Griots to apply the wax and would the same machine to use the autoscrub be able to remove the wax as well as compound a car? Thanks I appreciate it. I will purchase your book so that I can learn your techniques. Would this be ok for the autoscrub and wax removal and compounding? Griots Garage 6 Inch Heavy Duty Random Orbital Polisher
What polisher do you recommend for the Nanoskin Autoscrub system?
but I would love a good machine for Nanoskin Autoscrub to eliminate clay barring, t
he 3" Griot's to apply the wax and would the same machine to use the Autoscrub be able to remove the wax as well as compound a car?
You need a full size DA to use the Nanoskin pads the 3" Griot's won't work for the 6" Nanoskin pads.
You can use the 4" Nanoskin pads on the 3" Griot's polisher I would have to look to find a thread I have on this somewhere.
The 3" Griot's is not strong enough to compound, polish and remove wax off a car.
I use the Griot's 3" polisher to,
Machine apply waxes and sealants.
Machine wetsand thin panels.
Hope that helps...
I understand the 3" for applying waxes and polished sealants. I saw they have nanoskin kit you can use w/o a machine. But if I decided to use a machine what is good for compounding, removing wax, and nanoskin? Thanks
