Need a 1" polisher
Need a 1" polisher
Recently I received an e-mail asking me about 1" polishers.
I so much prefer to type and share information on the FORUM and not in an e-mail because on the forum tens of thousands of eye balls can read and benefit from the info whereas in an e-mail or any other kind of direct message, only one set of eyeballs sees the info,
For good or bad, here is what I sent my friend that asked the question, I just would like to get more out of my typing time.
My favorite polisher for doing work with a 1” pad is the RUPES Nano in Long Neck. It’s just so freaking handy and convenient due to the small compact size and reach of the long neck.
Doing Edge Work with RUPES Nano in Rotary Mode - Mike Phillips Style
https://www.autogeekonline.net/foru...pes-nano-rotary-mode-mike-phillips-style.html
The other options at Autogeek are,
FLEX PiXiE – has 1” backing plate and 3” backing plate
https://www.autogeekonline.net/foru...es-new-flex-pxe-80-10-8-ec-mike-phillips.html
The new Griot’s GR3
https://www.autogeekonline.net/foru...iots-gr3-rotary-polisher-1973-camaro-z28.html
All of the above are great choices and will get the job done.
Another option is to get the FLEX PE14 in either corded or cordless version. I recommend the cordless version. You can get a 1” backing plate for this rotary and not only do surgical buffing but also so many other things.
Review: FLEX PE14 Rotary Polisher by Mike Phillips
https://www.autogeekonline.net/foru...-flex-pe14-rotary-polisher-mike-phillips.html
Battery Time - FLEX Cordless Polishers - Real World Detail by Mike Phillips at Autogeek
https://www.autogeekonline.net/foru...real-world-detail-mike-phillips-autogeek.html
How to machine scrub tires using the Cordless FLEX PE14
https://www.autogeekonline.net/foru...ine-scrub-tires-using-cordless-flex-pe14.html
Please consider asking questions on the forum – it’s a LOT easier for me to share info versus the above in an e-mail.
Hope this helps,
Mike Phillips
Second the Rupes Nano 1" in rotary mode for surgical polishing. IMO the 3mm orbital is worthless (stalls a lot), but the 12mm is awesome.
I've made some tight areas clean with my Nano. It's a good tool and has its place. I need to buy the extension for it.
