Need a new Quick detailer ( I think )
luckydawg
Active member
I have been using Kenotek SRS for several years now- and have found it to be just what I need. Only problem is I cant find it for sale anywhere and need a replacement product. Any former SRS users found anything close?
Cost is not an issue for me for the most part- so what have you folks found that you like ( please dont even mention products like beadmaker )
Thanks fellas!!
Optimum No Rinse Wash & Shine is a true breakthrough in car care. It’s a multi-purpose product that serves as a rinseless wash, a quick detailer, and a clay lubricant, depending on how much water you add. You don’t have to be a chemist to formulate your own excellent car care products; just follow the directions on the bottle! Plus, this product does not require rinsing. You can conserve water and still get your vehicle beautifully clean.
This is from Autogeek
Sent from my SM-N960U using Tapatalk
Correct, Kamikaze Overcoat by itself is also very nice.
Expensive, but imo the Kamikaze products are worth the price tag.
OK
The carpro product is a concentrate that needs to be diluted- so how much of the finished carpro solution do you mix with the overcoat?
OK
Ech2o 1:15
Kamikaze Overcoat 1:15
So if I make 15 oz. I will just do 1oz of both then fill with water. You obviously can add more Overcoat if you would like. Overcoat was not made to be diluted but I do and love the look it gives when a bit is mixed in with Ech2o.
Even when you use Overcoat by itself, a little bit goes a LONG ways. Like, mist it on a microfiber then wipe, don't spray it directly on panel
If you aren't looking to mix up your own stuff, meguiar's hybrid ceramic detailer is very good and readily available.
Meguiars hybrid ceramic detailer is nice. I also like mixing Ech20 with a sio2 spray. I feel my Overcoat and PA products are to expensive to mix. I use Shine supply clutch or Griots 3-1.
Straight out the bottle i like Griots Speed Shine is a great cleaning QD and their BOSS detailer is Awesome.
I'll cast another vote for Ech2O, but I don't play mad chemist and mix it with anything. I simply dilute it 1:20 as recommended by Carpro and use it everywhere. Really like the stuff.
I too was a Kenotek user and still have a partial bottle on hand in the garage. I switched over to Ech2O when I started using coatings, but liked the Kenotek so much I couldn't part with it. Sounds like I'll need to use it sparingly to make what is left last as long as possible.
I seem to recall when reading about Sonax Brilliant Shine Detailer, people have mentioned the Kenotek SRS as being quite similar. I haven’t used it myself but might be worth a look, it’s a very good spray detailer/sealant.
I love the scent of Ech2o and highly recommend it as a spray detailer, drying aid and even for interior vinyls and plastics. The aqua marine scent is so slight and subtle but leaves an unmistakably fresh smell.
Ethos DEFY is my go to quick detailer
Also acts as a cleaner and protectant
It is hands down, the slickest product I’ve ever used...and it’s immediately after wiping with the dry side of a microfiber towel.
My gripe: It atomizes too well. I have to hold the nozzle very close to the surface, or half of it will fly off into the ether.
here's another option, looks to be similar by description...
Finish Kare 425 Extra Slick Final Body Shine
autogeek_2268_172346559
