need advice about my car
pagaz
hello ,
what u think ^ ?
how i can improve the colour of the car ?
i will happy hear advice\tips :)
tnx
i have this products :
polish uc + hex orange pad
v7 + black light
clay kit carplan
I would
  1. Wash
  2. clay
  3. polish
  4. IPA
  5. seal/wax
  6. Learn to say thats good enough.
I would
  1. Wash
  2. clay
  3. polish
  4. IPA
  5. seal/wax
+1 but skip the IPA step assuming you will wax vs seal. the car is in good shape but could use a good polishing to improve clarity. BL & V7 should do the trick. Your going to need polishing a wax pads typically white and black to red.
And welcome to AGO!
I wouldn't skip the IPA... trying to think when it would be beneficial to skip......
Sent from my DROID3 using Tapatalk 2
ultimate compound with hex orange pad (by hand) will improve the colour ?
how i can split this steps in couple days ?
And welcome to AGO!
Why skip, I thought IPA was good to remove oil residue?
What would happen if he did skip the IPA and there was still oil residue and he applied the wax/sealant?
Wow skip ipa? I even use menzerna top inspection after claying to ensure the utmost bonding to my paints clear coat. Call it overkill but wax and sealant adhesion is important to me.
If waxing after polishing you do not need to do the IPA wipe. Yes if doing a sealant then removeing the oils is manditory.
I've used all sorts of waxes after polishing without doing an IPA wipe. You need to be careful doing an IPA wipe with just diluted alcohol because it's easy to induce scratches then you'll be working backwards. This is why I said skip it if just planning to wax. BL & V07 work well together.
is necessary to do polish to my car ?
Why can't a Glaze be used?
Steps: IMO
Correct the paint
Sealant
Wax
Glaze
Followed by a Nice wash and Quick Detail spray (Poor Boys Spray glaze truly brings out the pop)
Art
Been thinking about that as I glazed the red Prius.
If your paint is already corrected why not add another layer of protection!?
Which in this case would be Glaze
I have a Nova coming up, Tune In...
Art
i live in israel , here the weather is very hot .
how i can spilt the steps in days ?
Can you get shade?
no :( .
i was thinking to do this Early in the morning but i have limit time of 2hours
befure the sun came out :(
told me to not do it direct sun or when the wind hot ,
so i not have options
thets my quation ,
how do this in stages ?
There's only 2 ways to do steps.
1. Do a step or two of your procedure on the entire car and then do more the next day.
2. Do part of the vehicle completely.
Since you may have to wash and dry the car every day, option 2 is your best bet.
Example:
Do the front clip through all the steps you are doing.
Tomorrow, do the roof and rear clip.
Next day do the doors.
Jim
