Hey all. Just joined the forum.
So I just took off some headlight protection film which the PO put on the car shortly before selling it (so its about 2/2.5 years old now) I believe its LaminX. I took it off using plenty of steam and took my time but it still left a bunch of adhesive residue behind. Pics attached below.
Tried applying some 3M adhesive remover on the passenger side headlight as a test as I have a spare headlight anyway, but it did not really help. Any tips on how to efficiently and safely remove the residue would be appreciated.
Also, regarding headlight polishing, which grit is recommended to stop at before applying clear (plan on using Spraymax 2k clear and headlight primer). I've heard mixed advice that ranges from stopping at around 800 grit so the clear has something to "grip" on to, to going all the way to over 4000 grit to get the lens as clear as possible. I tried restoring a third brake light as a test and went up to 5000 grit, and the clear came out cracked and uneven, could this be due to the surface not being scuffed up enough? Would appreciate some advice and tips on the whole headlight polishing process in general as I would like to get it right to first time so I don't waste time/money sanding off the 2k clear.
Thanks in advance!
Thanks in advance!
