Need ADVICE!
outlander
hI GUYS! i HAVE A QUESTION AND I KNOW THAT I WILL GET A GOOD ANSWER. LAST WEEK JUST FINISHED DETAILIN MY STEPDTR"S 2008 NISSAN ALTIMA BLACK. WHEN SHE WENT OUT WITH IT SHE SCRAPED THE RIGHT REAR FENDER ON A POLE. NO REAL DAMAGE RESULTED EXCEPT IT LEFT A STEAK OF WHITE PAINT ABOUT EIGHT INCHES LONG AROUND THE FENDER. hOW CAN I REMOVE THIS BEFORE SENDING IT TO A BODY SHOP. I HAVE A PC WITH ORANGE AND WHITE PADS WITH MENZERNA IP AND FP. SHOULD I TRY TO WET SAND THIS 1ST? AND IF IT'S RECOMMENDED HOW DO YOU WET SAND. NEVER ATTEMPTED THIS BEFORE AND I THINK I WOULD BE SCARED TO ATTEMPT THIS.Feed back pleaseIm the MAN
Use the least aggressive combo first and then move up if necessary. Meg's Ultimate Compound by hand works great.
:whs: If your going to wet sand for the first time, I suggest practicing on either a test panel from a junk yard or a car that you don't mind F'n up. If you start with 3000 grit and a soft "roller block" you can relatively safely get a feel for it. :cheers:
