Need Audi dealer recommendation for service in NYC area
hwt
Firstly, thanks y'all for a great forum, not only extremely helpful, but civil! Very enjoyable!
Tangentially related to detailing, as every time I have had my allroad in for service at local Audi dealers, they damage the finish in some way, I wondered if any of you might recommend a dealer in the NYC area (cast a wide net) that does consistently good mechanical work and is not otherwise careless. :help:
Thanks in advance.
Not sure where you should go, but just make sure to tell them NOT to do a courtesy wash or anything of the sort (I've even been told to put a sign in the car reminding them). Other than that, they just don't get how careful they need to be and at a minimum they probably lean on, over, etc... the car (and if you're really unlucky like I was they'll be so kind as to wash it for you and totally destroy the finish). And you might want to consider taking pictures when you drop off the car or at least do a walk around with the service manager pointing out how flawless your finish is, and then double-check it when you get the car back.
