Siciliang35
- Mar 21, 2015
- 12
I had a few brutal scratches on my black g35 that i got most out by wet sanding with 1500/2000/and then 2500.
This is the first time I've done this , first time using compound polish. I watched plenty of vids and read on it.
I got some turtle wax rubbing and polish compound. A harbor freight wool pad and polish pad that goes on the drill ....
So here's my questions .......
Actually the first thing i did was use touch up stick that i ordered online on one of the deepest scratches . It was aboyt 2 inches long. I let it dry for a week and sanded it level with 2500
I then tryed rubbing compound with a drill attachment on the rest with no good results ... Now this scratch had to be from either car wash or shopping cart becuase it goes all across the bottom , about 5 feet long and very thin, it also is zig zaged, and has little space between the 5 feet. Also left a few other deeper scratches on top part of door. Anyway after trying compynd And polish with no good results i started wet sanding.
I wrapped the sand paper around a small wood block aboyt 1 in wide and 1.5 long. Got some of the scratches oyt with 2000 and most oyt with 1500.... Then went over it with 2000 and than 2500.....:
Now this left dull spots...: looked like when You breathe on a window...... Went back over it with rubbing compound on the drill attachment and then with polish....
It came out preety good but it still looks hazy.....
Questions are
1 how long do i have to rub the compoynd for on one area?
2 does the compound take away hazyness???
3 how much compound in one spot ?
4 does the polish take away the hazyness ? What is the purpose ?
5 as for the touch up stick..... Its not as dark... Will the clear coat darken it? Both are ordered online with paint code.
6 when do i apply and how many clear coats? .
7 what is used remove compound and polish when need be?
Questions are
