Need Extractor Requirements
YankeeFan
Tried different Advanced Searches but couldn’t find specific information. We have 3 cars with light colored interiors. like to get an extractor to clean them all up. What are good requirements for a non-business used extractor? I saw one selling close by with the following specs, will they work well or just suffice?
60 PSI Demand Pump
3 Stage Vacuum Motor (137" of water lift)
Single Cord Operation
Instant 150-degree heat
15 ’ of 1 1/4 inch Vacuum Hose
15’ of 2500 PSI Solution Hose
5 gallon tank capacity
Thanks,
Howard
Since you're using this for personal / home use, I would strongly encourage you also look at a McCulloch MC1385 steamer and a standard Bissel type extractor. I actually use that combo on cars I do as a side gig and together they works great. The steamer is very handy around the home too. All depends on your budget and usage. Personally, I can afford and would love to have a full blown $1,300 extractor but I already have both of the above and don't do as many interiors yet to justify one.
Here's a quick example of what I was able to do with both in not very much time.
Interior Detailing by PDQS4 | Photobucket
Thanks for the suggestion, I will keep it in mind if this falls through. I have the opportunity to buy a used extractor locally but didn't know if it is strong enough to pull water up and if the 150 degrees was hot enough.
Howad
60 PSI Demand Pump
This sounds like a good option. When I use an extractor I am using it to do a final rinse and pull out all of the dirt/grime that I just released by scrubbing, therefore Water Lift is what I look at the most. The 137" is very good.
60 PSI Demand Pump
Thanks,
Howard
just rent one for 20.00 at ace hardware,they usually rent the thermax extractor heated.
