Need Help in Polishing a Black 2000 740 iL BMW
hudson1gua
Hi,
I might be asking for too much, but I am pressed with time. I have a Black, 2000 BMW 740 iL I have to do a full swirl/polish/wax job, scheduled tomorrow...yipes...The paint is not too bad, has a lot of swirls, no scratches, no holograms..its been garage kept, but the Blk needs to come back out again..I have LC pads = White, Orange, Green, Grey.. a Flex DA 3401, and Flex Rotary, and access to a PC 7424.. Menzerna IP, SIP, Power G, and sealant/waxes.
Any tips on procedures, and combinations to get it right the first time..greatly appreciated..I will mke it a point to post some B&A shots as well..
Thxz everyone,
DH
It would be best to do a test spot first as Mike always suggests. You can try the 3401 with white and SIP for starters, if not enough then white with PG, if still not working then orange with PG.
Sorry for no before shot. It was too early in the morning to see anything. Results from:
1. Flex Rotary/LC White Pad at 1200 rpm with Mezerna PG.
2. Flex 3401 DA/LC Green Pad with Mezerna IP.
3. Flex 3401 DA/LC Green Pad with XMT-3000.
4. Flex 3401 DA/LC Black Pad with Mothers S&G.
Thanks for the tips,..I will track the next one real good..
