Need Help Removing Paint Splatter From Car
pwgsx
So........my wife drove thru some white paint that someone dropped on the highway yesterday, not sure if its oil based, spray paint or what but its stuck on good. I know I can get it off of her paint but the textured plastic is where I am at a loss for what to use. Is there a product anyone would recommend that wont discolor the plastic? Help View attachment 75665View attachment 75664
The sooner you get it off the easier it will be. As the paint hardens and cures it will become more difficult.
I would first try with mineral spirits. If that doesn't cut it, I'd step up to an enamel reducer, then lacquer thinner, then acetone, in that order and as necessary. You can be quite liberal with the mineral spirits and even the enamel reducer, but if you find that you need lacquer thinner or acetone you have to be a little more discriminating with their usage.
2Black1s is the man for paint questions but another product I’d throw out is Tarminator as that is safe on most surfaces I’ve tried and should help. But do a test spot in an unseen area to be sure it is safe.
Seems there is hope, fingers crossed. Plan is to start with the pressure washer, then mineral spirits, enamel reducer and see what happens. I ordered the paint remover on amazon but it will arrive tomorrow.
my nephew spray painted his garage with a sprayer, didn't realize he had gaps where he was spraying and he sprayed his motorcycle on the inside
he used a pressure washer....on every surface including the leather bags :( it took it right off the clear coat, no plastic that I know of, but it carved into the leather on the bags, it was a mistake to try on leather
i'd start with a green scrubby pad and some apc
he had little flecks left on the clear coat, btw, and I as able to get them with a clay bar and lube :)
good luck, sir
and be careful with oil based solvents (thinner, spirits, etc) and oil based materials (plastic)....test spot :)......not meaning to step on toes, but I'm shaking my head a bit and suggesting caution, once you chemically dissolve or change the surface, there is no going back
Another piece of advice....get some damnn mudfflaps lol. That would have minimized the paint sling and kept it more concentrated on the mudflap.
And 2 black1s is spot on for the paint, as fil has used that method for line paint. Dunno about plastics
good luck, sir
Test spot where it can't be seen easily. Using a stronger chemical doesn't mean to slap it on and hope it works.
I’ve had a similar situation with yellow line paint. I used bug and tar remover. I saturated a small area at a time let it sit and then wiped it away with a soft terry towel to avoid scratching the textured plastic. Good luck!
