ShineTimeDetail
- Sep 26, 2010
- 2,032
Ok so last year had more problems with the plumbing along with the pump I was using to pump the water up to the pressure washer. Originally it had a small electric pump but I made a mistake on my first detail I accidentally had the pump running with no water going through it. I went out a bought a harbor frieght clear water pump cause it was cheap and I needed something fast.($30). Well all the plumbing is pvc and I keep breaking conections loose if I don't turn the pump off when I'm done with the pressure washer right away. The pump is a 600 gph. What size pump can someone recommend me at a reasonable price? Also that HF pump seizes up if I let it sit for more that a day! Does anyone also have suggestions on what to do with the plumbing work? Thanks guys and happy holidays!
