Need help!!!
jlws1aamd
Hello my name is Jimmy, I am new to the auto detailing industry. I've just started a small mobile detailing company. I have purchased most of the equipment needed to began. The problems I am having is what wattage generator to use for my shop vac 12 gal 5hp.I also have a 2200 psi pressure washer with a 65 gallon water tank and can't get the water pressure to work without a water pump.What kind of water pump should get to move the water through the pressure washer.Your help will be greatly appreciated. Thank you!!!!
