Rsurfer
- Jan 26, 2007
- 14,159
- 26
Looks like something off a Mars rover or a sci fi vehicle
My neighbor hated his run flats on his BMW so much he replaced them with regular tires.
And you know what the Mars rover has trouble with in its wheels?
There’s a Rock Stuck in NASA’s Mars Rover’s Wheel
My neighbor hated the noise and rough ride from the run flats. If they were really that bad, I don’t blame him for changing them
Run flats are garbage.
The ride is trash and with low profile tires you are way more likely to bend a wheel especially with the soft alloy bmw oem wheels.
I have 2 bmws and got rid of the run flats with less than 200 miles on the tires.
To me that does not look like what the sidewalls will look like but looks more like a cutaway to show
So far I have just slightly over 2,000 miles on them so I really haven't formed any opinion
What did he hate about them?
If I was living in America I would certainly hesitate to take a long trip without investing in a spare and jack and stuff
It says you can travel 50-75 miles with a flat so you would be good to go in an urban environment but not crossing Arizona or Montana or something
I actually checked with a couple of tire shops in Anchorage before we shipped it over here and apparently nobody sells new donut spares
I hated them as well for the above stated reasons. Mike, if and when you decide to replace them with regular tires..just get a cordless inflater, Ryobi makes a good one and a tire repair kit. I went one step further and put a small 1.5 ton hydraulic jack in my trunk.
So, one more check mark in the FAIL column
These Bridgestone Run Flats don’t hold air for $#!t
I just backed the car out to wash it and the tire light was on so I flipped the display over to the tire pressure screen and one tire is down to 27 which triggered the warning light and the rest were 3-4 pounds under spec
That’s after sitting for less than two weeks since our last drive
I was going to wash it and get the cover on because we are headed to Alaska soon but now it’s got to go to town for air first
PITA
For all the things you do around the house and garage..you should get a small air compressor.
