Need polish recomendations
Red Orc
I have A Griot's Garage 6" polisher coming today but I can't decide on polishes.
The vehicle is a red 2011 Mitsubishi Outlander Sport.
The paint is in very good condition other than some faint swirl marks I'd like to get rid of.
Right now the plan is to get Menzerna PF2500 and either SF4000 or SF4500.
The question is
If the only defects I have are mild swirl maks could I just usethe PF2500 or should I use 4000/4500 after that?
Or could I just use the SF4000 alone?
The question is
I believe you could use the SF4000 alone but it would add considerable time / effort even for just mild swirls. I'd do the PF2500 followed by SF4500 if you really want a great shine. I have done the same thing with these products with good results.
FYI, FG400 is also a great product and after using it last weekend I'd highly recommend FG400 followed by SF4500. Unbeatable IMHO.
Hope this helps! :xyxthumbs:
From your description, Menzerna SF-4000 sounds like the right product to eliminate minor swirls and it finishes out to a high gloss shine. You could use Menzerna PF-2500 and follow it up with SF-4000 for maximum correction and shine..
Thanks that helps a lot!
The description says FG400 is for "heavy imperfections" so I probably don't need that.
Edit
Just placed an order for PF2500, SF4000 & Mr Pink shampoo.
And LC Hi-Gloss CCS 6.5 Inch Polishing Pads
3 green
3 white
3 red
