need some help
dchristo
hey guys, I have a 2013 F 150 sterling grey. I have polished it with GG boss correction cream with a GG mf fast cutting, then with the mf fast finishing pad, them I used menzerna sf 4000.
now, the paint has no swirls or scratches and is slick as a baby's bottom, BUT now the clear coat is hazy or just not as clear as it should be or used to be
what did I do wrong and how can I fix it.
TIA
David
It is probably haze from the MF pads. Try a spot with a foam finishing pad and the Menz SF4000 and see if it makes an improvement.
I have the HF polisher, which foam pad should I use ?
Do you have any foam pads on hand? If so, what are they?
I have a couple of LC yellow and orange
I think white is as aggressive as I'd go but you could try a small section with the orange, no pressure and 4-5 passes.
