Need your suggestions on my car!!!
MawiPR
Hi my name is William I'm new to this forum I want to know you personal and professional opinion and suggestions on my situation woth my car that has swirls and water spots on the paint and even the windshield this is not a fancy car or anything its a daily driver but its my baby sense is my first one. That said I am a complete novice on this the only thing I know is because I have been reading and seeing a lot of video from Meguiars, Chemical guys, Autogeek allmost everything from youtube and the forum but I thought it would help of you guys look at the paints condition you could have a good idea of the situation I'm in. The car is an Scion xB 2012 2nd Gen.
I was asking what product would you recommend me.on getting what pas snese I reed that Microfiber one are better than foam pads, wich polisher is a good novice one people said to me a lot of thing but my top 3 are the Meguiars v2, Porter Cable 7424XP, GriGra . All of the are DA I read that are the safest for a novice like myself. And if you could inform me.on what pads to use. Thank you ill be uploading all the pictures of my car thank you Forum. ;)
Sent from my SAMSUNG-SGH-I317 using AG Online
I would get the Griot's DA. More power then Meg's, PC and lifetime warranty.
Pads- MF pads cut faster but foam will finish down better.
Your paint does not look bad. The easiest way to get started with polishing and making it simple are Meg's 105 and 205. You can tackle your car with those two polishes and some pads.
Don't forget to clay and mask out before you start polishing.
I'm in the same situation and asking the same questions. Paints good just needs to be better.
Thanks a lot you are the only person who actually said something in my post thank you I am great full for you're answer
In addition to the products recommended, I'd add the Meguires Ultra Compound and Ultra Polish.
I had never used a DA before, but used those products with a polisher on one of my cars in far worse condition than yours and got it looking new in most areas very easily. The paint gleams now and is smooth as glass. I found them both VERY easy to work with and I was able to find them in stores locally.
Thank you a lot I was also reading of that ultimate line of them herd some great things
