*NEW* 3M 5000 Grit Foam Discs!
Nick McKees37
McKee's 37 Product Support
The finest, highest uniform grit sanding discs available!
Finishing out with 2000 grit wet/dry sandpaper was once considered finishing out with a high grit paper! The advent of 3000 grit and then 4000 grit sandpapers changed the way professionals finished out a sanding job. 3M is once again rewriting the standard with the introduction of 5000 Grit Ultra Fine Finishing Discs!
Available in 3", 5" and 6" sizes.
3M Trizact 3 Inch 5000 Grit Foam Discs 30362
3M Trizact 5 Inch 5000 Grit Foam Discs 30562
3M Trizact 6 Inch 5000 Grit Foam Discs 30662
I think Mike Phillips has a thing or two to say about these...maybe he'll chime in. :)
Check these out...
Lots of questions answered here,
3™ Trizact™ Foam Discs 5000 FAQs
Front
Close-up
:xyxthumbs:
Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
Did some comparison testing between,
#1500 Grit Sanding Discs - Meguiar's
#1500 Foam Backed Finishing Discs - Meguiar's
#3000 Foam Backed Finishing Discs - Meguiar's
#5000 Foam Backed Finishing Discs - 3M
I'll let the pictures do the talking...
From left to right...
#1500 Grit Sanding Disc, #1500 Foam Backed Finishing Disc, #3000 Foam Backed Finishing Disc and #5000 Foam Backed Finishing Disc
At the #5000 mark you're really starting to restore reflectivity to the paint...
#3000 & #5000 Grit Wetsanding Marks Removed
with a DA Polisher
[video=youtube_share;uCHJdZY9Abs&hd=1"]#5000 Grit Wetsanding Marks..." target="_blank">#5000 Grit Wetsanding Marks...[/video]
I'll help on the cutlass, if you help me sand and buff my boss lol!
Thanks
Kody
I have a 1972 Cutlass coming up that needs to have a show car finish and this means sanding the paint flat to remove all orange peel.
Anyone interested in seeing this project done? How about helping out?
If it's on the weekend, I'm in. I have to drive from the Tampa area.
