New A4 in metallic grey. Need need LSP suggestions
alowe
I have been looking at a second car, and it may be the A4/RS4, it would be in metallic grey, yeah I love the color. Plan on 106FF and DWG after. What would you suggest to top it with to make the color POP/SPARKLE?
Andrew
Andrew
Are you looking for a nuba or a sealant?
Nuba-Souveran Sig II or Max Wax
Sealant- UPGP
Using a UDM:
106FF white LLC CSS
DWG
IPA wipedown
845 White LLC CSS or UPGP hand apply?
Need some assistance if I should go Carnuba or Sealant, and what would be best and why?
Using a UDM:
106FF white LLC CSS
DWG
IPA wipedown
Your IPA wipedown should be after polishing not after DWG. This to get the oils out of the 106 for a clean surface for the sealant or wax to bond to. I would lay 2x UPGP 1x DWG and either 1x UPGP or a nuba.
Thanks boss, how does the 845 sound for a nuba? I have also read much about the UPGP. It is a spray, is it going to last? Just seems that a liquid would not last as long as a liquid or paste. Just an old schooler here, LMK.
No experience with 845, but if you like it, give it a try. You can always go over it with something else. Again no experience with durability on UPGP. It's only been about 3 weeks since the last coat of UPGP. Ultima claims 3-4 mos. durability. I'm planning to re-coat with UPGP once a month. Only takes 10 min. after wash and blow dry.
May have to give it a try then.
i read somewhere 845 was good on silver so maybe grey is good too for Collinite!
We shall have to see. Its cheap so I am getting it. Should look good combo'd with the DWG?
