Meghan
Super Moderator
- Mar 3, 2006
- 15,033
We have been listening to our customers, and been hearing a desire for a few extractors. So... we now have added the Aztec to our line. I will personally vouch for this machine since I just used it last night to take out some spots left on my carpet from the builder. You can see on the product page the pictures of the area I cleaned... this machine is magic!
A little info about it...
The Aztec Hot Rod Hot Water Extractor deep cleans carpet with the power of hot water. No spot or stain will remain! The Aztec Hot Water Extractor is designed with the pro detailer in mind. Quick heating, a lightweight, portable design, and extra long hoses make the Aztec a priceless addition to your detailing arsenal.
This compact unit offers a lot of the features of the big extractors, but it’s more user-friendly for the mobile detailer. The spotter is the perfect size for carrying at only 17" high, 18" long, and 13" wide and a weight at 18lbs (without the solution.). The 50 ft., 12 gauge cord allows you to work on cars away the power source. For auto detailing for large numbers of vehicles, The Hot Rod’s design makes cleaning easier and faster. The 2-gallon recovery and 1.5-gallon solution tanks keep The Hot Rod running for hours. Complete more cars in a day with results that keep customers coming back.
Check it out for yourself!
Personal observations... very lightweight, easy to handle, warms up fast, takes hardly no time to clean
- 200°F Heated solution tank (110°F water heats to 200°F in 8 minutes)
- Ready to use when dwell time on pre-spray is completed
- 1.5 Gallon solution tank capacity
- 2.5 Gallon recovery tank capacity
- Piston pump delivers 60psi
- 1400 Watt heating element
- Lights indicate when heating and when temp. is reached
- Power requirement less than 15 AMPs
- 3 year limited warranty
- 50 ft, 12 gauge single flow cord
- 16ft 1 1/4" ID flexible vacuum hose
- 16ft 3/16" ID spray hose
- Weight of Spotter without solution is 18lbs
- Maneuvers easily on 2" casters
- Easily accessible to fill, empty and clean
- Dimensions of Spotter: 17" high, 18" long, 13" wide
- Spotter furnished with transparent 3" upholstery detail tool
