New Dodo Juice Items
agpatel
Is AutoGeek going to be getting any of the new Dodo Juice range.
LOW ON EAU. This is our rinseless wash, brought out to beat the hosepipe ban where it still exists in the UK and for those customers who live in flats (without their own outside tap) or for showgoers who need to spruce up their cars on-site. Optimum No Rinse (ONR) is the most famous competitor. Our version is a lubricious yellow liquid (smells of pineapple and apple) that cleans panels before they get buffed/dried to a high shine (so there is no rinse stage). Lubricants help prevent contamination scratching the car although we recommend it is used on lightly soiled vehicles only. The water behaviour due to these lubricating/glossing oils is pretty impressive… check out the water sheeting immediately after (although the irony is you may not have access to a hose!). Priced at 8.95 GBP RRP for 250ml and 16.95 GBP RRP for 500ml. Dilutes 1:200 (similar to ONR).
250ml:
500ml:
SUPERNATURAL MICRO PRIME. Most pro detailers have a bottle of Lime Prime and most amateurs having tried it. It's well loved, but some users found that if it wasn’t worked enough on soft paint then the abrasives wouldn’t break down and could mar the paint slightly; not an issue when it is fully worked or used on hard paint, but it was a small issue nevertheless. Lime Prime Lite was an alternative, but was oil heavy and could be tricky to use on some paints, so we created this Supernatural pre-wax cleanser and ultra-fine polish… Micro Prime. Like Lime Prime, so nice and workable by hand or machine, but with even finer micro-abrasives. This allows it to clean and polish softer paints without marring, without the tricky application and oiliness of Lime Prime Lite – so you get the best of both worlds. What’s more, it can cut a treat as well, restoring our VW Golf Mk2 solid red sun roof panel back to red (from pink) with minimal filling. Those particles are small but they’re mighty. We welcome testing vs similar products and are interested to see whether people find it better than Lime Prime. Priced at 14.95 GBP RRP for 250ml and 24.95 GBP RRP for 500ml.
250ml:
500ml:
SUPERNATURAL ACRYLIC SPRITZ. This is a spray sealant or ‘protection detailer’, like Red Mist – but it’s WATER based, so there’s no solvent to attack fresh wax layers and it’s a high-performance acrylic rather than a more traditional sealant recipe. Whilst Red Mist was giving about 4-6 weeks durability/longevity, the longevity of this can be measured in months… we reckon it is far closer to a normal liquid sealant, and offers perhaps 3-4 MONTHS of durability, maybe more. It won’t beat Supernatural Hybrid, but for a quick spray product it does amazingly well. Given the non-interference and relatively low price and this should be a great product for those wishing to apply a sealant layer to bodywork, trim or wheels (it suits almost all surfaces) or for those wishing to add an interim ‘top up’ layer of protection to their waxed/sealed vehicle. Priced at 12.95 GBP RRP for 250ml and 22.95 GBP RRP for 500ml.
250ml:
500ml:
SUPERNATURAL CARNAUBA GLAZE. For those who want a natural quick detailer or glaze, we created this high carnauba solids spray. It is silicone-free and gently cleans a panel before leaving behind a layer of high grade carnauba wax. This won’t have the kind of durability/longevity of a spray sealant like Acrylic Spritz, but it won’t be far off Red Mist. A great glaze and quick detailer for cars that sport carnauba wax finishes. Priced at 14.95 GBP RRP for 500ml.
SUPERNATURAL TYRE DRESSING. Tyromania is a bit too matt in terms of finish for many users, so this is the answer. Supernatural Tyre Dressing. It leaves a satin finish on tyres and is a pleasure to work with. A mild water-based emulsion that dries to a finish that gives no sling or splatter. ‘Just the right amount of shine’ rather than an artificial wet look. Priced at 12.95 GBP RRP for 250ml.
SUPERNATURAL WHEEL SPONGE. The Supernatural Sponge has been a real success and showed that detailers can, and do, use sponges. This is a black foam version shaped to fit the curved rim of wheels, and with pointed ends that can go into wheel spokes more easily. So now you don’t need to get your Supernatural Sponge cross contaminated with wheel grime… use the Supernatural Wheel Sponge for those dirtier areas. Priced at 8.95 GBP RRP.
SUPERNATURAL MICROFIBRE ORBITAL CUTTING PADS. Similar to the Meguiars’ microfibre DA cutting pads, designed to give more bite to orbital machine polishers. In 130mm and 80mm sizes to suit standard 125mm backing plates and 75mm spot plates. Priced at 7.95 GBP RRP for 80mm and 9.95 GBP RRP for 130mm.
80mm:
130mm:
CAPTAIN CANOODLE SYNTHETIC MICRONOODLE WASH MITT. The natural wash mitts we do (Tribble, Wookies, Yeti) are 100% natural so can rot or moult if not perfectly maintained. This is our solution to the problem, instead of delisting or changing the spec of our natural mitts, we have gone completely synthetic and introduced a micro-noodle microfibre wash mitt, i.e. it has lots of noodles to create a deep and soft artificial pile. It can’t be killed easily, it’s soft and holds plenty of water. At 8.95 GBP RRP it’s also good value and cheaper than the natural mitts. Please note that this item is NOT AVAILABLE UNTIL LATE JUNE.
‘ALIEN’ CLOTHING RANGE. Hoodies and T-shirts in white, or tie-dye green, with a Dodo Juice logo on the front and alien artwork (courtesy of pj) on the back saying ‘Take me to your Detailer’ instead of the usual Dealer/Leader. Great heavyweight hoodies, priced at 32.95 GBP RRP in S,M,L,XL,XXL and good quality T-shirts priced at 19.95 GBP RRP in S, M, L, XL, XXL.
Fingers crossed!
The carnuba glaze and micro prime sure look interesting!
Don't yet own any Dodo, but some of these new items look enticing!
OH JUST GREAT :rolleyes::rolleyes::rolleyes:
More stuff I have to buy....
We need some Powered by Dodo Juice stickers.... Just sayin...
I have been waiting for these. But I haven't found anyone who sells them yet. Even one across the pond.
thanks for the insight on there new products. hoping that they can get them.
I receive emails from Waxamomo and they advertised the Dodo.I have some of the LOW ON EAU on the way.They have it in stock.
Hopefully AG will have these new and exciting products offered in the near future so we don't have to order from across the pond ;)
It's been tried multiple times. They won't even get the 500 ml back...
I would get the micro prime and the acrylic spritz in a heartbeat!
The following new Dodo Juice products will be available at Autogeek in the coming weeks. :dblthumb2:
  • Rinseless Wash
  • Supernatural Micro Prime
  • Supernatural Acrylic Spritz
  • Supernatural Carnauba Glaze
  • Supernatural Tyre Dressing
Stay tuned for a review of all of them. :righton:
  • Rinseless Wash
Yahoo! :dblthumb2:
  • Rinseless Wash
Wow, that's awesome news. Guess I'll be placing another big order here in a few weeks. Cannot wait to try out the carnuba glaze.
  • Rinseless Wash
Good! Can't wait to try it. I can wait another week or two instead of placing another order with someone else now.
How do I get one of those sweet hoodies?
Just sent Dodo Juice an email asking if any of the clothing items are going to be available in the States from online stores like Autogeek, so when I get a response I will post it back here.
