New Flex XCE How many passes ? - Help needed (Not Flex XCE specific)
Hi folks, I wonder if someone could guide me in the right direction at all ? I have now got the above machine after putting it off for so long, I have watched all sorts videos and tutorials and have become a little confused between 2 techniques used on the Forensics detailing channel and the one on the Apex Detailing channel on Youtube which i hope someone could explain to me.
On the Forensics channel, he was doing a tutorial on the 3401 VRG on a pretty trashed black VW, he did 6 passes with a medium pad (he said do 90 seconds to 2 minutes per set, but he must have been going much longer than that). Anyway, once he did the first set, not all the defects went away, so he did another set with the same combo and it was then at the right level. My question is, surely you wouldnt want to do that all over the car would you ? Would he have been better off doing another test panel but with a firmer pad to see if that got the damage out in 1 set rather than doing 2 sets with the same pad and compound combo ?
Now on the Apex channel (the bit I'm confused with), he only does 2 passes, checks defect removal and if not enough does another test with a more aggressive pad.
My confusion is why is there such a difference in the number of passes they are both doing per set ?
Confusing the hell out of me.
I hope someone can explain it to me
