new from mn
jeeper85
great forum and new to detailing, been reading this forum for a year now has help me out , have wolfgang, DP, duragloss but not have use it just not sure about it. did use wolfgang and 845 over the winter and it was great but now want to try duragloss have#601,#105 and #951. question is for doing total paint correction with duragloss. wash.clay WGTSR, then#105,#601 #951 or 845.​
:welcome: To Autogeek Online! :props:
Wolfgang Total Swirl Remover
is a great product and will remove 2000 grit scratches. While it might not seem fine enough you'll be pleasantly surprised how great a neglected panel looks after using it.
Duragloss
You can use Duragloss #105 and #601 in a couple of different ways...
With a dual action polisher:
1. Apply Duragloss #601 first leaving it on the panel. With another soft foam pad apply Duragloss #105 directly on top of the #601, let haze, and buff off with a microfiber towel.
2. On the face of a clean soft foam pad, apply 4 drops of Duragloss #105 then add 1 drop of Duragloss #601. Do this in about 6 locations on the face of the pad, place the pad on the panel, then switch on the machine..
The key to understanding these products is Duragloss #601 is a catalyst or an activator. When it comes in contact with Duragloss #105 there's a chemical reaction which increases its durability and gloss.
I would wait over night or at least 8 hours for the sealants to cure then apply Duragloss Aquawax #951....
Welcome also from a fellow Minnesotan!
Sent from my SPH-L710 using AG Online
