Elliot@Autogeek
- Apr 24, 2017
- 362
Below are the new products from Ultima, McKee's 37 and Wurth!
Ultima Acrylic Waterless Wash Concentrate is an Acrylic Polycharger boosted formula that safely cleans all surfaces without the need for hoses or buckets! Formulated with specialized lubricating agents, Ultima Acrylic Waterless Wash Concentrate encapsulates dirt, bugs, and grime so it is safely and easily wiped from the surface. If you’re in need of a quick wash and protect, but find yourself without water or a hose, Ultima Acrylic Waterless Wash Concentrate is all you need!
[TABLE="width: 400, align: center"]Ultima Acrylic Waterless Wash Concentrate is an Acrylic Polycharger boosted formula that safely cleans all surfaces without the need for hoses or buckets! Formulated with specialized lubricating agents, Ultima Acrylic Waterless Wash Concentrate encapsulates dirt, bugs, and grime so it is safely and easily wiped from the surface. If you’re in need of a quick wash and protect, but find yourself without water or a hose, Ultima Acrylic Waterless Wash Concentrate is all you need!
[TR]
[TD="class: product-info-table-2-header, colspan: 3, align: center"]Ultima Acrylic Waterless Wash Concentrate Bundle[/TD]
[/TR]
[TR="class: alt, bgcolor: #EFEFEF"]
[TH]Item #:[/TH]
[TD="class: code"]ULT-8116CB[/TD]
[/TR]
[TH="width: 103"]Our Price:[/TH]
[TD="class: price"]$19.99[/TD]
[/TR]
[TH="width: 103"]Sale price:[/TH]
[TD="class: sale-price"]$17.99 - You Save $2.00 (10%)[/TD]
[/TR]
[/TABLE]
Clean & protect some of your most touched surfaces!
Ultima Screen Cleaner & Protector is a non-toxic, non-streaking, and ammonia and alcohol free formula that not only cleans away smudges, dust, and fingerprints but also protects all touch screens, plasma screens, LCD and LED screens, laptops, computer monitors, ebooks, navigation systems, eyeglasses, sunglasses, camera lenses, and mirrors. Ultima Screen Cleaner & Protector bundle also helps to reduce glare and adds a slick layer of protection that helps prevent scratching and stops germs from permeating touch-screen surfaces. Unless you’ve been living under a rock for the past 10 years, you’ve got a surface that could use a Ultima Screen Cleaner & Protector treatment!
[TR]
[TD="class: product-info-table-2-header, colspan: 3"]Ultima Screen Cleaner & Protector Bundle[/TD]
[/TR]
[TH="width: 103, align: right"]Item #:[/TH]
[TD="class: code, align: left"]ULT-5122-BUN[/TD]
[/TR]
[TH="width: 103, align: right"]Our Price:[/TH]
[TD="class: price, align: left"]$12.99[/TD]
[/TR]
[TH="width: 103, align: right"]Sale price:[/TH]
[TD="class: sale-price, align: left"]$10.99 - You Save $2.00 (15%)[/TD]
[/TR]
[/TABLE]
McKee's 37 Fast Water Spot Remover is a powerful cleaner designed to remove topical water spots from your clear coat before they have a chance to cause permanent damage. McKee's 37 Fast Water Spot Remover is non-abrasive, non-caustic and is 100% safe for use on all exterior surfaces – including paint, wheels, glass, chrome, and more! With the ability to break down calcium deposits, McKee's 37 Fast Water Spot Remover can also be used as a first step removal product when dealing with the harsher type 2 and 3 water spots. Don't let water spots ruin your perfect finish – get rid of them FAST with McKee's 37 Fast Water Spot Remover!
[TR]
[TD="class: product-info-table-2-header, colspan: 3, align: center"]McKee's 37 Fast Water Spot Remover[/TD]
[/TR]
[TH]Item #:[/TH]
[TD="class: code"]MK37-680[/TD]
[/TR]
[TD="class: price"]$17.99[/TD]
[/TR]
[/TABLE]
Conforming foam scrubs any surface you need scrubbed!
Griot's Garage Ergo Wave Foam Scrubber is a versatile scrubbing foam pad constructed with an open-cell foam that is resistant to tears. Perfect for use on vinyl, plastic, leather, rubber, paint, upholstery, carpet, wheels and more, Griot's Garage Ergo Wave Foam Scrubber can be used on both the interior and exterior of your vehicle – in fact, you can probably find uses for it in the home as well! Griot's Garage Ergo Wave Foam Scrubber will contour to fit any surface that needs scrubbing and three finger holes allow for a firm grip. Step up your scrubbing with Griot's Garage Wave Foam Scrubber!
[TR]
[TD="class: product-info-table-2-header, colspan: 3"]Griot's Garage Ergo Wave Foam Scrubber[/TD]
[/TR]
[TD="class: code, align: left"]GR-10520[/TD]
[/TR]
[TD="class: price, align: left"]$6.99[/TD]
[/TR]
[TD="class: sale-price, align: left"]$5.99 - You Save $1.00 (14%)[/TD]
[/TR]
[/TABLE]
Degrease and restore instantly!
Wurth Brake & Parts Cleaner is a fast and efficient way to clean and degrease all brake parts, either disc or drum. Formulated without chlorinated solvents or hexane, Wurth Brake & Parts Cleaner degreases instantly and will leave no residue behind. Use Wurth Brake & Parts Cleaner to clean and degrease brake linings, drums, cylinders, springs, disc brake pads and more! Wurth Brake & Parts Cleaner is a powerful spray that allows you to remove oil and grease from your brakes without having to disassemble!
[TR]
[TD="class: product-info-table-2-header, colspan: 3, align: center"]Wurth Brake & Parts Cleaner[/TD]
[/TR]
[TH]Item #:[/TH]
[TD="class: code"]W-189099107[/TD]
[/TR]
[TD="class: price"]$10.99[/TD]
[/TR]
[TD="class: sale-price"]$8.99 - You Save $2.00 (18%)
[/TD]
[/TR]
[/TABLE]
