VISITOR
Active member
- May 10, 2007
- 9,859
- 3
THE BOSS™ Foam Cannon
Meet the ultimate foam delivery system. In mere seconds THE BOSS™ Foam Cannon can blanket your car in rich, cleansing foam.
-The most innovative foam cannon on the market
-Our exclusive Auto-Mix feature perfectly mixes your concentrate
-Durable precision-machined stainless steel manifold
-Patented, no-leak vented reservoir cap
-Includes a Stainless Steel Quick Disconnect Coupler
FOAMING SURFACE PREP
BOSS™ Foaming Surface Prep is the most intense foam cleaner in the BOSS™ Foaming System.
-Rids surface of abrasive particles, avoids wash-induced scratches
-High pH levels breakdown waxes and sealants, providing a clean slate for paint correction
-Ground-up formulation blended for THE BOSS™ Foam Cannon Auto-Mix system
-Dual-layer foam formula extends dwell time, enhances cleaning action
-Primary foam clings to paint, softening road film & organic contaminants
-Secondary foam releases and carries the abrasives to the ground
-Extended dwell times... up to 10 minutes of intense cleaning action
FOAMING SURFACE WASH
This fluffy foam gently loosens, lifts, encapsulates, and releases contaminants, deep cleaning your paint while avoiding wash-induced scratches.
-Rich, clingy snow foam avoids wash-induced scratches
-pH-neutral to retain existing waxes and sealants for routine maintenance
-Primary foam clings to surface softening road film, organic contaminants
-Extended dwell times... up to 10 minutes of quality cleaning
FOAMING POLY GLOSS
Add hydrophobic protection and get more miles out of your shine by test driving this leading edge polymeric snow foam.
-Hydrophobic polymers enhance gloss, surface slickness, and protection
-Extends the lifespan of existing waxes, sealants, and coatings
-Produces remarkable water repelling capability
-Dual-layer foam extends dwell time, enhances cleaning action
-Polymers deliver fast drying and anti-static properties for a long lasting clean
EXTRA-LARGE PFM® EDGELESS DRYING TOWEL
Need superior drying power? Unleash 1,044 square inches of thirsty ultra-premium microfiber.
-Go big on size, thickness, and absorbency
-More drying, less wringing for faster vehicle drying
-Edgeless design ensures maximum safety
-Soft and safe double-ply, long-looped microfiber
THE BOSS™ LED SWIRL-FINDER LIGHT
This versatile LED light is a superior paint evaluation tool and a great all-around work light.
-Dual LEDs deliver wide flood or narrow focus to evaluate even the finest defects
-Wide flood light is rated at 320 lumens, 5000K color temperature
-Narrow focus tip light puts out 120 lumens, 6000K color temperature
-Rechargeable lithium-ion battery delivers 3 hours of illumination
-Dimensions: 9" L x 1" D x 1" W
DUAL WEAVE INTERIOR TOWELS, SET OF 3
Your first-class interior deserves a first-class towel. Enjoy superior cleaning and surface buffing with these versatile towels.
-Unique dual-weave delivers gentle dual-purpose cleaning
-Thick unique diamond-patterned, waffle-weave side lifts and traps common contaminants
-Low-nap, tight-weave side excels at light dusting, fingerprint removal, and final buffing
-Ideal when teamed with our interior cleaners, detailers, and dressings
-Satin edges and radiused corners ensure safe wiping of all interior surfaces
-Enjoy gentle, lint-free performance on even the most delicate surfaces
2,050 PSI ELECTRIC PRESSURE WASHER
This washer generates up to 2,050 psi to power our BOSS Foaming System and any other aquatic projects you might have.
-Flows 1.4 gallons per minute
-Includes 4 nozzles: 0°, 25°, 65°, and a Turbo Tip
-2-in-1 design detaches from cart for easy carrying
-Features 35' power cord with Ground-Fault Circuit Interrupter in plug
FOAM CUSHION FOR COMPACT SIT-ON CREEPER
Get more cush for your tush! Enhance the comfort and convenience of your Compact Sit-On Creeper.
-Custom designed to fit your creeper
-Durable cushion weighs over 1 pound
-Measures 18 1/2" x 10 1/2" and 1/2" thick
DRILL POLISHER ADAPTER BIT
Turn your drill into a detailing superhero. Use for waxing and polishing paint, headlight restoration, metal polishing, and more.
-Transform your drill into a high-speed rotary polisher
-Accepts Griot's Garage BOSS™ 2" or 3" Backing Plates
-Rotary action delivers exceptional defect removal characteristics
For more additional products, visit their home page...
Hold tight, AG should have these soon!
FOAMING POLY GLOSS
