New Griots Products, New Bucket Kits, & New Water System
Elliot@Autogeek
New car wax and auto detailing products
The essentials to get you started washing your car the Griot's way!
The Griot's Garage Starter Car Wash Kit contains the Ultimate wash Bucket, a pint of Griot's best car wash, a super soft micro chenille wash mitt, 3 tire swipe applicators and 3 microfiber towels for use with your favorite quick detail spray. This money-saving kit is great for both beginners and professionals alike because it contains the world's best car wash bucket and a handful of car care products that everyone can use. The Starter Car Wash Kit makes a great gift, too!
Griots Garage Ultimate Car Wash Bucket is proof that not all buckets are created equal. This masterpiece of thoughtful engineering is designed and constructed so well it almost doesn’t feel right calling it a bucket, something that is normally cheap and used for projects around the house. This must-have detailing accessory was designed from the ground up to be the hands-down ultimate car wash bucket, bar none. A lower grill allows heavy grit to sink to the bottom where it can't contaminate your Wash Mitt. An upper grill holds your wash tools. Genius!
Built-in measuring cup ensures you never use too much or too little Car Wash!
The lower grid traps dirt particles; the upper grid is perfect for holding wash mitts and wheel brushes
Griots Garage Starter Car Wash Kit
Sale Price: $74.99
Retail Value: $96.97
You Save $21.98 (23%)
Item ID: GR-WASH-KIT
Get the most out of your gallons!
Griot's Garage Pump Head Dispenser is a heavy-duty pump used with Griot's Garage gallon bottles for quick and convenient dispensing. Perfect for use on thicker products like the Griot's Garage Car Wash, and Griot's Garage Wash & Wax, Griot's Garage Pump Head Dispenser allows you dispense only the amount you need, when you need it! Never worry about wasting product again - with the Griot's Garage Pump Head Dispenser you get 1 oz. per pump - nothing more!
Sale Price: $3.50
Retail Value: $3.99
You Save $0.49 (12%)
Item ID: GR-11805
Professional 5 Gallon Wash Bucket- GRAY
5 Gallon Professional Wash Bucket with Grit Guard – GRAY
5 Gallon Wash Bucket Combo - GRAY
5 Gallon Wash Bucket System with Dolly – GRAY
Complete Car Wash System with Dolly - GRAY
Grit Guard® Dual Bucket Washing System - GRAY
Get clean, di-ionized water – simply!
Simple Chuck's Double Chuck Spotless Water System is a water de-ionization unit that provides approximately 400 gallons of “spotless” water, allowing you to wash your car without fear of water spots! Manufactured to be as simple to use as possible, Simple Chuck's Double Chuck Spotless Water System features a stainless steel input hose, a pressure regulator, quick disconnects for input/output hoses, wheels, and foldable handle, and is shipped to you with a fresh set of cartridges – once it's delivered you are ready to go!
Our Price: $369.99
Item ID: CR-SCDC
Keep your Simple Chuck performing its best!
The Simple Chuck’s Double Chuck Spotless Water System is the easy-to-use water de-ionization system that provides a water-spot free wash. It works by filter water through a negatively and positively charged ion resin that clings to salts, minerals, and spot-causing particulates in your water, removing them before your water hits your vehicle’s surface. Simple Chuck’s Double Chuck Spotless Water System Replacement Filters are used when your original filters change from the original blue to gold.
Our Price: $189.99
Item ID: SC-DCRF
