When you say soak, should I spray directly on the spot or saturate the microfiber then let it sit on top? How long should I let it soak for?
I've used paint thinner before as a last resort. NOT LACQUER THINNER! Regular paint thinner is pretty weak. IF you have to resort to using it, do so only on the tar itself and don't let it linger on the paint!
If it's an isolated blob of tree sap..start with a plastic razorblade
I'm no expert, but that doesn't look like tree sap to me.
Are you sure it isn't some kind of paint defect / bubbling of the paint?
why not lacquer thinner?
I have used purell or equivalent with decent results.:buffing:
I use Goof off and a Q-tip works great for things like this.
After soaking it for a while, carefully use a plastic razor blade and it should pop right off. I have had a couple cars with these size spots and this is what I did to remove them. Follow up with a polish if necessay. The piece should come off in 2 or 3 chunks. Just my 2 cents. Good luck
Put a couple drops of purrell on it or any of the instant hand sanitizers, let it sit for 10 mins then try wiping it off with a microfiber towel
