Elliot@Autogeek
- Apr 24, 2017
- 362
Quartz-based protection that lasts!
GYEON Car Care offers a full range of quartz-based vehicle coatings, along with all of the tools and products needed to maintain the treated vehicle’s finish. Not only are the formulas offered the most technologically advanced, they’re also designed to be easy to use at any skill level, appealing to detailing hobbyists and professionals alike. GYEON forgoes fancy coloring and scents, providing genuine, long-lasting results that will turn heads.
GYEON is gaining a reputation worldwide as a source for the best quality car coatings. Each GYEON product is carefully crafted to provide the best results, and the best value. GYEON provides innovative solutions for high-quality surface protection that lasts longer than traditional options. That means each application yields months of protection, as opposed to mere weeks!
Expert level oxidation and defect removal!
GYEON Q2R Marine Polish Step 1 makes quick work of any and all surface imperfections that tend to collect on your boat’s surfaces. The high-quality Japanese abrasives used in the formula of GYEON Q2R Marine Polish Step 1 allows it to easily cut through even the most severe oxidation and defects that plague your boat’s gelcoat! Because GYEON Q2R Marine Polish Step 1 doesn’t use any silicone or fillers, the results you see when you buff it off are true results that won’t just fade as the fillers do. GYEON Q2R Marine Polish Step 1 is also designed to finish off to a much higher gloss than you would expect from such an aggressively abrasive polish!
Our Price: $59.99
Your boat deserves this level of gloss!
GYEON Q2R Marine Polish Step 2 will correct moderate to light defects and polish out to a glossy and perfect finish. GYEON Q2R Marine Polish Step 2 is a great product to use either after your primary correction step or as a one-step gloss refresher! The lack of fillers in GYEON Q2R Marine Polish Step 2’s formula means that you can trust that the results you see are there for the long-haul! The low dust generation of GYEON Q2R Marine Polish Step 2 will make clean-up and buffing off a breeze!
Our Price: $59.99
Even your protection film needs to be Renewed!
GYEON Renew is a unique product that will finally give you the ability to breathe the life back into your dull and faded PPF or self-healing paint film! GYEON Renew contains light abrasives that will work to gently correct the haze and oxidation that your PPF collects overtime without causing permanent damage. The protective additives in GYEON Renew will re-up the protection qualities of your PPF and restore its resistance and self-healing capabilities! GYEON Renew will easily correct your dull and oxidized PPF and restore it back to the gloss it had when you first got it!
GYEON Renew
Our Price: $15.99
The easiest gloss you’ve ever seen!
GYEON Quick Detailer is the perfect tool for you to combat the light soil that your car experiences on a daily basis. GYEON Quick Detailer will greatly increase the glossiness of your paint, wax, or coating in one simple step! The level of lubrication in GYEON Quick Detailer ensures that you will not instill any scratches or swirls in your paint during application even if it is left to completely dry out! GYEON Quick Detailer can also be used as a drying aid after you wash your car to increase the safety of your drying AND generate a high gloss finish at the same time!
Our Price: $13.99
Your all-in-one solution to your leather care conundrum!
The GYEON Mild LeatherSet is an all-encompassing kit that allows you to take your lightly soiled leather to an entirely new level of protection and ease of care! The GYEON Mild LeatherSet give you everything you will need to complete the multi-step process of applying an effective and durable quartz coating to your leather. Once completed, your leather will be properly protected and extremely easy to care for in the future! With the GYEON Mild LeatherSet, you will never again have to worry about your expensive interior looking dull and faded after only a year!
Our Price: $36.99
GYEON Strong LeatherSet
Our Price: $39.99
GYEON Mild Leather Cleaner
Our Price: $15.99
GYEON Strong Leather Cleaner
Our Price: $17.99
A gentle approach to cleaning a sensitive surface!
The GYEON LeatherBrush gives you the perfect tool that you need in order to gently and effectively clean your leather surfaces. This exceptional brush is made using soft horse hair bristles that generate enough scrubbing potential to remove tough oil, dirt, and discoloration from your leather without causing permanent damage in the process. The handle of the GYEON LeatherBrush is made with natural wood that has rounded edges. These rounded edges will ensure that there is no accidental ripping or tearing during the scrubbing process!
GYEON LeatherBrush
Our Price: $6.99
Perfect application, no matter the surface!
The GYEON Microfiber Applicator was designed to be the ideal applicator for a wide range of products and surfaces. The high-quality microfiber of which the GYEON Microfiber Applicator is made maximizes comfort and surface safety while you are working. The absorbent sponge inside the GYEON Microfiber Applicator ensures that the applicator will always be saturated enough to ensure safe application! The GYEON Microfiber Applicator even has a pocket sewn into it that will fit snuggly around your fingers, greatly increasing ease of application and greatly reducing the risk of the applicator slipping!
GYEON Microfiber Applicator 2 Pack
Our Price: $12.99
Our Price: $59.99
Our Price: $59.99
GYEON Renew
Our Price: $15.99
Our Price: $13.99
Our Price: $36.99
Our Price: $39.99
Our Price: $15.99
Our Price: $17.99
GYEON LeatherBrush
Our Price: $6.99
Our Price: $12.99
