new lake country course foam pads. Prototype review
3kgt2nv
lake country sent me some of their new pads to try out and give them some feed back on. I am not a professional detailer. I do detail a host of planes, cars and boats evey year on the side but I am far from a full time detail person.
the video pretty much gives my first thoughts about the pads. sorry for the quility i was trying to hold the camera and use the buffer one handed so there are some parts that get kinda shaky.
Today 5/3/12 I will be doing more testing and posting the results here as well.
[URL=http://s191.photobucket.com/albums/z156/3kgt2nv/?action=view&current=2012-05-02_20-01-38_209.mp4][/URL]
Looks nice. Please keep us informed of how they work out.
How well do they finish down?
What is the cut comparable to?
Durability?
Where would pink fall into the color ranges? Heavy Cut, Light cut?
Was there a "name" on the label of the samples? I am assuming its the Hybrid but might be another new line?
Do you work all your cars/projects using the same technique/speed you demonstrated in this video?
Do you work all your cars/projects using the same technique/speed you demonstratedin this video?
the pink is going to be the replacement for the course green pad from what i got from emailing with the support person that i am dealing with. there was no name on the plastic and all the invoice showed was prototype sample.
to me personally i think getting rid of the green pad is a smart move since they have two pads the same color.
The pink is move of a very heavy cutting pad, much more aggressive than the course green pad is.
I do not normally work my projects like this, this was more of a trial and fast review.
Normally when compounding I start spreading at speed two and step up to 5 once the product is spread never normally even using speed six. The pad i found allowed for much quicker cutting and the denser foam didnt absorb the cutting compound as fast as the older pads did so i was able to run at a faster speed. this video was like i said a fast demo.
To day I did the whole truck using the lower spped to spread the product and then moving up to a faster speed. the results were almost the same either way that i used them. here are some pics of the result.
the cab was done totally with using a max speed of 4.5 to 5 on the buffer
for the plow i tried a couple of different speeds and pressures to see the results
the results were the same with all the different methods I tried so im willing to guess its just how fine of a finish your looking for. granted this truck was in horrible shape to start but it also has much harder paint and no clear coat like a car of boat would have.
The pads did make more "dust" than the old pads do but it also did not get clogged like the older pads. I did notice that the foam was almost totally untouched by all the use.
great work/results! thanks for posting findings and responding, it looks fantastic after you were done
What's is the benefit they are promoting course foam as having? Faster cut?
no pictures, dont use photo bucket to host pictures for forums, photobucket pictures do not last long for some reason so there is always empty images. whenever you are posting pictures on a forum use that forums picture uploader as then it will stay on the server and wont have broken picture links....on the top tool bar it says upload photos click on that and upload your pictures, then to get them onto the forum click on the picture in your gallery and copy and paste the link that contains the [IMG} [/IMG} tags
