New Lake Country Pads
Meghan
Super Moderator
We have some new Lake Country 6.5" pads in stock and we would like for a few of you to test them out. So if you have a polisher and you work with 6.5" pads please respond to this thread if you would like to try them out. They are especially made for water based products and we will be sending two pads to a couple lucky forum members. So post a reply to this thread and we will select a couple members!
PS- we have tried them out and they are great!
Lake Country' s Hydro-Tech Foam Pads are designed specifically for the application of water-based polishes and compounds. European pre-polymer foam prolongs the working time so you have more time to create a flawless finish. Hydro-Tech Inch Foam Pads are ideal for professional, body shop-safe polishes. Choose any combination of three pads with this special 3 pack.
Lake Country Hydro-Tech 6.5 Inch Foam Pads are made of imported European pre-polymer foam. This long-wearing, high quality foam is less absorbent in order to keep the majority of polish on the pad's surface. You'll experience a longer working time with your water-based polishes and compounds, resulting in less product used to achieve the perfect finish.
Water-based polishes can soak into some foam pads like, well, water. That requires you to keep reapplying polish to the pad. With Lake Country Hydro-Tech 6.5 Inch Foam Pads, water-based polishes work longer and you use less polish. You'll save time and polish!
The Lake Country Hydro-Tech 6.5 Inch Foam Pads accomplish defect removal and finishing in just one step. This special foam composition leaves no marring so, even after compounding with the blue cutting pad, the finish is nearly wax-ready. Think of these pads as all-in-one polishing and finishing pads.
Lake Country Hydro-Tech 6.5 Inch Foam Pads are available in two varieties:
Cyan Advanced Cutting Foam - The blue foam is designed for compounding and swirl removal. This closed cell pre-polymer foam restores oxidized and heavily swirled paint. Looks can be deceiving; the blue pad looks coarse but actually finishes with no marring. You'll achieve an almost wax-ready finish in one step. That's another way the Lake Country Hydro-Tech 6.5 Inch Foam Pads save you time.
The blue cutting foam works well with Menzerna Power Finish PO 203 and Meguiars Ultra-Cut Compound. Both polishes have great cutting power and a clean, glossy finish. Use either polish/pad combo on neglected finishes and watch the paint come to life!
Tangerine Ultra Polishing Foam - The tangerine foam is made for light to moderate defect removal and polishing. It has the cutting power just below that of the Lake Country orange light cutting pad, and the tangerine pad leaves a finish like you'd achieve with a gray finishing pad.
Use a finishing polish or fine swirl remover to create a deep gloss. Menzerna Super Finish or Wolfgang Finishing Glaze are two excellent choices for this pad.
Like Lake Country's other premium foam pads, Lake Country Hydro-Tech 6.5 Inch Foam Pads are made with high quality hook and loop backing. The pads work with a 5 or 6 inch hook and loop backing plate. The pads' size is perfect for a dual action or random orbital polisher.
The flat face of the Lake Country Hydro-Tech 6.5 Inch Foam Pads also helps to keep water-based polishes on the surface of the pad. The flat pads maintain full contact with the paint, and they have enough flexibility to hug the curves and contours of your vehicle.
Lake Country Hydro-Tech 6.5 Inch Foam Pads work with any type of polish but they're pre-polymer composition makes them ideal for water-based polishes. Water-based polishes are used by body shops and paint shops because the oils in silicone-based polishes will interfere with paint. If you want a professional quality finish, water-based polishes applied with applied with Lake Country Hydro-Tech 6.5 Inch Foam Pads are the way to go. They'll save you time and polish!
Pick me!!! :hungry:
I am thinking of buying new pads, and couldn't make up my mind whether to try the 5.5" or stay with 6.5" pads.
I would love to try them out for you.
I don't have the amount of experience with the PC that alot of others have, but I wouldn't mind trying them out. (I've only used 5.5's so far). I've polishing everything that I can get my PC on including a John Deere tractor, and I'm already ready to start placing orders for more pads since the tractor turned all of my pads green and it's hard to tell which ones are which.:bash:
I would love to try, only thing is I don't have a 6/5 in. backing plate (looks like another order needs to be placed :).
Would be a great addition to my new PC 7424XP that arrived at my door yesterday! :buffing:
Pick me! :dblthumb2:
:iagree:
I need to try them pads....Go ahead and send them to SC.....:kiss:
I have a Flex 3401 and would like to try them. Thank you.
Pick me! pick me! I have some details coming up I could use them for :) Im the MAN
I am in on trying some new pads. I have an Escalade, two Austin Martins, one Lambo, and a warehouse full of old muscle cars to try them out on.
I'd be willing to donate my time to give them a thorough workout.
Remember....."No tickie....no washie"
:buffing:
Pick me!
I've been thinking about moving away from the 5.5" pads I bought with my Flex and going to 6.5" pads so I have a little lip on the edges of the backing plate.
Pick me...and I might just buy some more 6.5" pads. (Does bribing work?)
-V
