*NEW* Marine 31 Gel Coat Heavy-Cut Cleaner Wax
Nick McKees37
McKee's 37 Product Support
You talked and we listened! Introducing Marine 31 Gel Coat Heavy-Cut Cleaner Wax - the best boat cleaner wax money can buy.
We have received an overwhelming amount of requests for a heavy cut cleaner wax since Marine 31 launched last March; needless to say we've been hard at work the last few months developing this product. With the new Gel Coat Heavy-Cut Cleaner Wax, we've essentially eliminated the need for a two-step compound and wax for most applications.
Marine 31 Gel Coat Heavy-Cut Cleaner Wax is the perfect one-step solution for removing moderate to heavy oxidation and staining on gel coat – standard and painted. Formulated using advanced micro-abrasives, proprietary cleaning agents and nourishing oils, Marine 31 Gel Coat Heavy-Cut Cleaner Wax maximizes color, gloss and surface smoothness while leaving a durable layer of high-gloss wax protection. Marine 31 Heavy-Cut Cleaner Wax is exceptionally easy to apply and remove and its unique formula does not dust or cake up.
Developing what is now known as the best boat cleaner wax was no easy feat. The goal with Marine 31 Gel Coat Heavy-Cut Cleaner Wax was to create a boat cleaner wax that doesn’t contain the big, chunky, sharp abrasives that, while effective at removing oxidation and surface staining, leave swirls and haze behind. Marine 31 Gel Coat Heavy-Cut Cleaner Wax had to also contain nourishing oils to hydrate the gel coat and, more importantly, a durable wax built-in to protect the gel coat against UV rays, salt degradation and more. After months of testing and countless reformulations, Marine 31 Gel Coat Heavy-Cut Cleaner Wax was born and it exceeds all expectations set forth by Captain Max!
Forget everything you know about a heavy duty boat cleaner wax and discover Marine 31 Gel Coat Heavy-Cut Cleaner Wax, arguably the best boat cleaner wax money can buy! In one simple step, Marine 31 Gel Coat Heavy-Cut Cleaner Wax removes oxidation and staining while leaving a glossy, durable layer of wax protection. This all-in-one boat cleaner wax will enable you to spend less time polishing and waxing and more time being out on the open water!
Marine 31 Gel Coat Heavy-Cut Cleaner Wax is guaranteed to provide more cut and longer lasting protection than any other boat cleaner wax currently available. You can use it with a foam or wool pad on a dual action or rotary polisher.
Marine 31 Gel Coat Heavy-Cut Cleaner Wax 16 oz.
Marine 31 Gel Coat Heavy-Cut Cleaner Wax 32 oz.
Marine 31 Gel Coat Heavy-Cut Cleaner Wax 64 oz.
