New McKee's Products are in!!!
Elliot@Autogeek
McKee's 37 have been working hard their new products out and here they are!
Cleans everything!
Use McKee's 37 Hi-Intensity All Purpose Cleaner Plus to clean virtually any automotive surface! Hi-Intensity All Purpose Cleaner Plus cleans vinyl and plastic interior surfaces, carpet and upholstery, tires, engines, leather, clear and colored plastics, and glass. McKee's 37 Hi-Intensity All Purpose Cleaner Plus can be diluted to tackle any job; one gallon of APC will make up to 11 gallons of ready-to-use all purpose cleaner! McKee's 37 Hi-Intensity All Purpose Cleaner Plus makes it possible to clean every surface with a single product.
McKee's 37 Hi-Intensity APC Plus forgoes harsh chemicals that are harmful to you and the environment and instead relies on smart chemistry. McKee's 37 Hi-Intensity APC Plus is strong enough to remove grease from engine bays, yet gentle enough to clean fine leather upholstery at the proper dilution ratio.McKee's 37 Hi-Intensity APC Plus leaves behind a fresh citrus fragrance inside the vehicle.
McKee's 37 Hi-Intensity APC Plus will not leave surfaces sticky, regardless of the dilution ratio. When a powerful cleaner is needed for engines, tires, and fender wells – dilute 4:1. For light to moderate dirt and grime inside the vehicle, dilute 10:1. Feel free to play chemist in your detail shop and experiment with the dilution ratios! No matter the dilution, McKee's 37 Hi-Intensity APC Plus will not leave a film on the surface.
Our Price: $14.99
McKee's 37 Hi-Intensity APC Combo - Launch Special! Limited Time Only!
Our Price: $30.97
Sale price: $22.99
Protect your headlights for up to 3 years!
McKee's 37 Headlight Coating is an advanced nano-glass ceramic coating designed to protect your polycarbonate headlight and taillight lenses for up to 3 years. McKee's 37 Headlight Coating is a high-solids formula and essentially adds another layer of clear coat to your lenses, leaving them well protected as well as crystal clear. After spending the time to restore your faded headlights (or to prevent your brand new headlights from fading in the first place!), make sure you protect them properly with McKee's 37 Headlight Coating.
Our Price: $59.99
McKee's 37 Headlight Restoration & Coating Kit - Launch Special! Limited Time Only!
Our Price: $100.95
Sale price: $69.99
Wipe on, walk away paint sealant!
McKee's 37 10 Minute Paint Sealant is an SiO2 enhanced, wipe-on, walk-away product that leaves a long lasting high gloss finish after just one application. Safe for use on all exterior surfaces, including paint, wheels, chrome, and even glass, McKee's 37 10 Minute Paint Sealant's hyper-concentrated formula is easy to use and will provide up to 6 months of protection! If you're short on time but don't want to sacrifice your car's finish, McKee's 37 10 Minute Paint Sealant is just what you need!
Our Price: $27.99
McKee's 37 10-Minute Paint Sealant Combo - Launch Special! Limited Time Only!
Our Price: $46.96
Sale price: $35.00
