Jaretr1
- Jan 29, 2011
- 2,391
I see this just popped up on the new products page:
]http://www.autogeek.net/highline-paint-thickness-gauge.html
Correcting paint can be daunting enough for first timers; adding in the possibility of burning through the paint can make it even worse! HighLine Meter Paint Thickness Gauge is one of those tools you do not want to start a project without.
HighLine Meter Paint Thickness Gauge is not the first of it's kind by any means. But, it may be the first (possibly only!) paint thickness gauge that is affordable enough for everyone! You don't have to be a professional body shop to appreciate how much easier the HighLine Meter Paint Thickness Gauge can make a detail. Before putting any polisher to paint, make sure you are aware of what you are working with!
HighLine Meter Paint Thickness Gauge comes packaged in a sturdy sunglasses-style, felt line cased.
HighLine Meter Paint Thickness Gauge gives you an accurate reading on both ferrous (Fe) and non-ferrous (NFe) surfaces in both mils and microns. The large, easy-to-see display flips when you need it to, making it easier to measure lower body panels and hard to reach areas. Before starting such a large project, use HighLine Meter Paint Thickness Gauge to get a read on the vehicle in question. You'll be glad you did!
HighLine Meter Paint Thickness Gauge features:
- Steel & Aluminum readings
- Pre-calibrated
- 0-40 Mils (Thickest reading capability available)
- On/Off button for safe pocket carrying
- Large LCD read-out with flip display technology
- Auto-switch technology with surface indication (FE/NF)
- Reads in both Mils and Microns
- 1 AAA batteries for long lasting reliability
- Large foot for stable readings
