New Products by Speedmaster!
Elliot@Autogeek
Speed Master Premium Glass Towel
No streaks, No smears, No dragging!
Speed master has long been a trusted name in detailing tools and accessories. They have continued to uphold that legacy with the creation of the Speed Master Premium Glass Towel! The genius diamond flat-weave design of the Speed Master Premium Glass Towel minimizes any streaking or smearing during the cleaning process. This makes sure that even the dirtiest windows and glass can be brought to absolute transparency with ease!
When you are cleaning your windows or glass, the towels and products you are using are of the utmost importance. Not just any shop towel will be able to get you the results you need when working to clear the plethora of contaminants and grime from your car’s glass. Most towels have longer fibers, which are the main cause of streaking when working on glass. The drag on the glass and create a trail of grime that we call a “streak”
__________________________
The Speed Master Premium Glass Towel uses a unique diamond-weave pattern to grab on to dirt and pull it away from the surface wihtout streaking or smearing - regardless of which glass cleaner is used!
The Speed Master Premium Glass Towel avoids this common problem by having drastically smaller fibers and a tight-knit weave. This ensures that the fibers generate as little drag as possible when being moved across the glass. No drag, no streaks!
The Speed Master Premium Glass Towel is absorbent enough to quickly suck up the grime and dirt once your preferred glass cleaner is applied. It will pull the contaminates deep into its fibers to prevent them from being redeposited onto your glass.
The Speed Master Premium Glass Towel was constructed to really be put through the wringer (pun intended). Its fibers are kitted tightly, which means they are much less likely to separate due to repeat use. The reduced drag of its diamond-weave construction also generates less friction, which reduce the amount of wear that the Speed Master Premium Glass Towel see over many uses. Towels may seem like a throw away wear piece, but there is no reason they shouldn’t be able to last through the long-haul!
Cleaning your glass doesn’t have to be the chore it has been in the past. The Speed Master Premium Glass Towel can help you see just how easy clear glass can be!
Our Price: $8.99
Speed Master Vac N' Blo Jr. Hand-Held Vacuum
Easily clean even the smallest crevice!
The Speed Master Vac N' Blo Jr. Hand-Held Vacuum makes cleaning your interior an absolute breeze! This hand-held machine can be used to either quickly vacuum away all the dust and dirt that collects on your seats and dash or expertly blow every speck of debris out of the niche crannies between the seat cushions. The Speed Master Vac N' Blo Jr. weighs less than 3 pounds, making it easy to deftly maneuver around your interior while you are cleaning!
The Speed Master Vac N' Blo Jr. Hand-Held Vacuum also features a blowing technique that allows you to dry your motorcycle or car quickly after a wash! This also helps with blowing dirt, dust, and air out of small area on the interior before vacuuming!
Nobody likes to spend money on purchasing a new tool simply to have to replace a year or two later due to wear and tear. To make sure that you are definitely able to get your fair share of use out of the Speed Master Vac N' Blo Jr., it was designed with extended durability in mind. The sturdy steel construction of the Speed Master Vac N' Blo Jr. means that you will likely have to replace the upholstery on your seats before you have to worry about replacing your Speed Master Vac N' Blo Jr.
The amount of power that is packed into this small, light-weight machine is certainly surprising! The Speed Master Vac N' Blo Jr. boasts an impressive .75 horse power motor than gives you enough suction or blowing potential to tackle any mess you may run into with your interior. This motor allows the Speed Master Vac N' Blo Jr. to move air at an outstanding 70 cubic feet per minute! That is quite a lot of air for such a tiny appliance!
The Speed Master Vac N' Blo Jr. Hand-Held Vacuum includes 6 different accessories, including a 20" extension wand for those hard-to reach areas, a upholstery tools for carpets, and a crevice tool!
The various attachments and accessories that come with the Speed Master Vac N' Blo Jr. really allow you to hone all that power for any cleaning situation that you may come across. The Crevice Tool fits easily between seat cushions and even into the space between your seats and your center console. The Dust Brush helps to lift the fibers of your carpet and upholstery to release the ground-in dirt, promoting a better clean. With the Air Inflator Nozzle, you will be able to focus the air flow tremendously, so you can get intense blowing action into even the smallest nook!
Whether you are detailing car professionally or just trying to make sure your own garage queen always looks its best, the Speed Master Vac N' Blo Jr. will give you all the power and potential you need to do so!
Technical Specifications:
Construction: Sturdy All-Steel
Motor: .75 Peak HP
Amps: 4.5 Amps
Watts: 500 Watts
Airflow CFM/FPM: 70 CFM
Cord: 12 ft. 2-Conductor cord
Dimensions/Weight: 16.5"x4"x5.5" / 2.7 lbs
Accessories include:
Upholstery Tool
Crevice Tool
Magic- Air Inflator Nozzle
20" Extension Wand
18" Flexible Extension Hose
Shoulder Strap
Our Price: $129.99
